Just another Factory 6 being fixed up |
Luke M |
Oct 23 2015, 12:26 PM
Senior Member Group: Members Posts: 1,371 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Well it's gotten to be that time finally. I've been collecting parts to do the repair on my 914-6 and now the work starts. The main issue is the hell hole/inner engine long, inner pass long, pass inner rocker panels are rusted out. The last part I was trying to source seams to be NLA. I sourced most of the parts from the good guys at Restoration Design. I received my order today for the last batch of things. Based on a few threads that I've looked over the outer shell to the inner engine long is currently not being made by RD. A few guys have made their own which looks like a real pain in the rear to do. I laid out all the new metal to see how things lined up. By the looks of things it will need some fine tuning to mate things properly. Before I start cutting into the chassis I'll build a few braces to keep things true.
Time for the pics... Attached image(s) |
Luke M |
Jan 30 2021, 07:11 AM
I spent all of Friday afternoon drilling out spot weld, cutting, and grinding away all of the old long section. What a PITA. Got it all cleaned up and ready so I can test fit the new NOS long today. I have some other work to get done before I can install it for good. I need to get a few more parts from RD. I also need to track down a plug end for the spot welder and rework the spot welder arms. I'm gonna try and use the spot welder as much as I can then finish with plug welds.
Attached image(s) |
mate914 |
Jan 30 2021, 07:56 AM
Matt Group: Members Posts: 749 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
I spent all of Friday afternoon drilling out spot weld, cutting, and grinding away all of the old long section. What a PITA. Got it all cleaned up and ready so I can test fit the new NOS long today. I have some other work to get done before I can install it for good. I need to get a few more parts from RD. I also need to track down a plug end for the spot welder and rework the spot welder arms. I'm gonna try and use the spot welder as much as I can then finish with plug welds. Floppy disk for grinders are simple the best. I'm not sure if your using one or not. They blend welds and remove material fast. I see your doing a lot of work, but your pictures are always clean? Looks very good. Matt |
Lo-Fi Version | Time is now: 14th May 2024 - 10:54 AM |
