Speedometer Jumping, Need your wisdom for a cure |
BeemerSteve |
Oct 25 2015, 03:54 PM
Member Group: Members Posts: 239 Joined: 2-September 15 From: Van Zandt, Wa Member No.: 19,123 Region Association: Pacific Northwest |
Hello everyone,
I'm still getting use to ALL 914 and still learning how it works. Having one 32 years ago doesn't help much and have to get back into it. My speedometer is not steady while driving....is there a cure? Thank you again |
TheCabinetmaker |
Oct 25 2015, 04:07 PM
Check the drive and angle gear on the lower, rear, starboard side of the transmission. Where the cable attaches. If it's loose or wiggles, it's probably dying.
Oct 25 2015, 11:30 PM
A cable that is starting to fail can also cause this.
--DD |
BeemerSteve |
Oct 26 2015, 08:18 AM
Check the drive and angle gear on the lower, rear, starboard side of the transmission. Where the cable attaches. If it's loose or wiggles, it's probably dying. Checked it....it's dying! Is it a obtainable item or repairable? Thanks again for the wisdom as I appreciate it..for sure! |
76-914 |
Oct 26 2015, 08:38 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,501 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Check the drive and angle gear on the lower, rear, starboard side of the transmission. Where the cable attaches. If it's loose or wiggles, it's probably dying. Checked it....it's dying! Is it a obtainable item or repairable? Thanks again for the wisdom as I appreciate it..for sure! Contact bdstone (Bruce Stone)on the board here. He should have some posts in the Classified FS/WTB: section. |
Lo-Fi Version | Time is now: 15th May 2024 - 11:54 AM |
