Radios...All dealer installed or factory?, Were all radios dealer installed? |
914time |
Oct 28 2015, 06:40 PM
Member Group: Members Posts: 68 Joined: 7-August 14 From: St. Paul, Minnesota Member No.: 17,750 Region Association: Upper MidWest |
Working to understand if 1973 and 1974 914 radios were always installed at the dealer or if any were installed at the factory.
Mike Bellis |
Oct 28 2015, 08:48 PM
914Sixer |
Oct 29 2015, 05:32 AM
You could order a factory radio in your car. Most dealers did NOT because they could make more profit by adding the radio. Most DID order the car with the antenna though so that part was plug and play. When the dealer did complete installation you never knew where the antenna would end up.
914time |
Oct 29 2015, 06:55 AM
You could order a factory radio in your car. Most dealers did NOT because they could make more profit by adding the radio. Most DID order the car with the antenna though so that part was plug and play. When the dealer did complete installation you never knew where the antenna would end up. Makes sense. So there could be a number of different brands and models of radios I assume? Can anyone tell from the pic what the brand, model and period correctness of this one is? Attached thumbnail(s) |
914Sixer |
Oct 30 2015, 06:16 AM
Looks like a Bowman Astrosonic. Period correct 70's because it has AFC switch and local/distant. Probably a mono radio.
Mark Henry |
Oct 30 2015, 06:39 AM
In Canada it would be an Audiovox, the Canadian VW dealer network had an exclusive deal with them.
I still have my Audiovox dealer installed cassette stereo in a box of my old 914 stuff, for their time they were actually a pretty decent unit. |
Mike Fitton |
Oct 30 2015, 07:23 AM
Senior Member Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest |
Yes you could order factory installed radio, Blaupunkt, Becker but you would have to wait for the car and would not get much of discount off sticker. Almost all 914's sitting at the dealer were waiting for dealer installed radio except for some of the 914-6's.
JeffBowlsby |
Oct 30 2015, 07:49 AM
914 Wiring Harnesses Group: Members Posts: 8,502 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I am not so sure that a 914/4 could be ordered with a USA market radio from the factory, I have not seen any evidence of that, but I do not have any factory USA-market price lists.
The antenna may have been orderable because the car is set up for that on the inside fender wall, but I have not taken an original paint car apart to see if the antenna hole was factory. I need to do that. I have price lists from Germany for German market 914s that indicated the availability of German market radios mostly for /6s, but also for 914/4 German market 914s. The only price list I have from a USA dealership suggests the radios offered were only dealer installed, USA market radios - Blaupunkt, Motorola, etc. http://bowlsby.net/914/Classic/OpEq.htm A list of some of the USA radios available, and note that USA market "Radio Installation Kits" from Blaupunkt and Motorola were available: http://bowlsby.net/914/Classic/Accessories.htm |
914time |
Oct 30 2015, 10:17 AM
Thank you for the replies.
Unfortunately it does not look like a Boman Astrosonic. Any other thoughts? |
Lennies914 |
Oct 30 2015, 10:32 AM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
914time |
Oct 30 2015, 10:44 AM
Thanks Lennie and Mark.
Lennie, do you know what model by chance? |
Lennies914 |
Oct 30 2015, 10:49 AM
Thanks Lennie and Mark. Lennie, do you know what model by chance? I'll take a look this evening (IMG:style_emoticons/default/beerchug.gif) |
Lennies914 |
Nov 2 2015, 05:10 PM
I just picked up a parts car this weekend that is equipted with a radio like this one. It also had the radio warranty card to go with it.
(IMG:http://www.914world.com/bbs2/uploads/post-312-1325019467.jpg) Would this be a factory installed? |
Mike Fitton |
Nov 2 2015, 05:55 PM
I just picked up a parts car this weekend that is equipted with a radio like this one. It also had the radio warranty card to go with it. (IMG:http://www.914world.com/bbs2/uploads/post-312-1325019467.jpg) Would this be a factory installed? No that is a dealer installed Motorola sapphire radio. Period Correct for that car. |
Lo-Fi Version | Time is now: 13th May 2024 - 06:48 PM |
