Ground location, Of factory console harness |
Porschef |
Nov 1 2015, 11:56 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Don't want to add another wire if I don't have to; without pulling the whole thing apart, can someone direct me to where it ties in to the chassis?
Thanks. |
stugray |
Nov 1 2015, 12:05 PM
The main one is where the battery ties to the chassis right behind the battery to the inner fender wall.
Porschef |
Nov 1 2015, 01:22 PM
Thanks Stu, I'll check that out.
JeffBowlsby |
Nov 1 2015, 04:31 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The 914 has several ground points, in addition to the one at the battery.
The ground for the center console gauges is accessed at the connections on top of the center tunnel, which enters the main chassis harness, and is physically on the divers side firewall under the relay board. |
Nov 1 2015, 04:36 PM
Relay board, underneath in engine bay
Fuse panel, inner fender well, need to drop the fuse box to see it Battery, inner fender well behind firewall Front lights are on the inner fenders up in the front trunk I think there is one more common ground point under the front cowl for the heater/blower/ washer and wipers. |
JeffBowlsby |
Nov 1 2015, 04:41 PM
Attached thumbnail(s) |
Nov 1 2015, 04:47 PM
Even better.
scyon90 |
Aug 29 2021, 12:09 PM
Newbie Group: Members Posts: 1 Joined: 3-September 11 From: Denver, CO, USA Member No.: 13,513 Region Association: Rocky Mountains |
Using this info years later, thanks Jeff ! |
StarBear |
Aug 29 2021, 07:16 PM
Senior Member Group: Members Posts: 1,885 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Ditto! (IMG:style_emoticons/default/agree.gif)
I even laminated a copy to keep in the car! |
Lo-Fi Version | Time is now: 17th May 2024 - 08:12 PM |
