Front turn signal gasket installation |
Harpo |
Nov 3 2015, 04:56 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
For the record I have tried searching but found nothing on the subject
My new gaskets for the front turn signal lenses seem too small. I can't get them to seal/seat properly. Hopefully there is a simple solution. I'm believe that rubber shrinks with age but these are new aftermarket seals. Thanks guys David |
AZ914 |
Nov 3 2015, 05:03 PM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
There should be 2 seals for each side:
1. between the body and bucket 2. between the lens and bucket Perhaps you have the body seal trying to go onto the lens? Just guessing. |
Mikey914 |
Nov 3 2015, 05:34 PM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Are they front turn signal or side marker len seals. The side marker seals are a balancing act with the lens and the base, and do stretch.
Mark |
Lo-Fi Version | Time is now: 14th May 2024 - 10:29 AM |
