| Blue6 |
Nov 4 2015, 06:45 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,057 Joined: 3-October 13 From: SoCal Member No.: 16,470 Region Association: Southern California
My 1974 1.8 completely stock has a problem. Every couple of days it will only stay running about three seconds. No mater how many times I try to start it, it just runs for three seconds then dies. Other days it will run great.
I checked the power to the fuel pump, and get 10.86 while cranking. When I plug the fuel pump back in and crank the engine, it doesn't do anything. No noise, no vibration. I removed the pump and jumped it with a battery, and it spins like it should. What am I missing. Thank you... |
Blue6 Resident 1.8 L-jet experts, a little help please... Nov 4 2015, 06:45 PM
timothy_nd28 Sounds like a failing dual relay Nov 4 2015, 09:44 PM
timothy_nd28 Grab a voltmeter and set it for DC. Put the positi... Nov 4 2015, 10:10 PM
Bleyseng Maybe a loose wire in the dual relay connector. Th... Nov 5 2015, 09:10 AM
Blue6 Thank you Timothy and Geoff for the info. I should... Nov 5 2015, 10:55 AM
Blue6 Geoff, checked that dual relay. Everything looked ... Nov 9 2015, 08:45 PM
timothy_nd28 Interesting, how long will it idle with the AFM co... Nov 9 2015, 08:59 PM
Blue6 When I start it using starting fluid, it will run ... Nov 9 2015, 09:52 PM
CooltimesJr not sure if this will help you or not, but the per... Nov 10 2015, 12:03 AM
CooltimesJr or maybe Dave will chime in since he is an admin t... Nov 10 2015, 12:05 AM
Blue6 Thank you Cooltimes, everything helps. With the he... Nov 10 2015, 10:43 AM
timothy_nd28 This seems odd. The fuel pump is turned on by two... Nov 10 2015, 01:09 PM
Dave_Darling Sounds like you have good avenues of inquiry here.... Nov 10 2015, 07:35 PM
Blue6 Been chasing wires, and so far everything looks st... Nov 10 2015, 07:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:01 PM |
