oil cooler plumbing |
BravoHotel |
Jun 11 2003, 06:32 PM
Member Group: Members Posts: 153 Joined: 5-March 03 From: Columbus, MS Member No.: 399 |
I've got the cooler. The sandwich plate/thermostat and new air dam are on the way. Now I have to decide what kind of hose to use. I think that braided hose is overkill...it looks cool, but no one will ever see it and it looks like a PITA to work with. Does anyone have experience with the slip fit "barbed" fittings and hose that Aeroquip, Russell and others sell. The fittings are rated to 200psi, which should be more than enough...plus much less expensive.
Any suggestions apprecitated BH |
drew365 |
Jun 11 2003, 06:41 PM
These are the good old days! Group: Members Posts: 2,004 Joined: 29-December 02 From: Sunny So. Cal. Member No.: 37 |
There was a thread on this about a week ago. What heat rating does the Aeroquip slip fit hose have? Their braided hose is only rated at 300 deg. I think that's cutting it a little close. Earl's is rated at 450 deg. What size cooler did you buy?
I just did some research and Earl's is also rated at 300 deg. McMaster-Carr has some rated at 450deg. |
Lo-Fi Version | Time is now: 29th May 2024 - 02:46 PM |
