oil cooler plumbing |
BravoHotel |
Jun 11 2003, 06:32 PM
Member Group: Members Posts: 153 Joined: 5-March 03 From: Columbus, MS Member No.: 399 |
I've got the cooler. The sandwich plate/thermostat and new air dam are on the way. Now I have to decide what kind of hose to use. I think that braided hose is overkill...it looks cool, but no one will ever see it and it looks like a PITA to work with. Does anyone have experience with the slip fit "barbed" fittings and hose that Aeroquip, Russell and others sell. The fittings are rated to 200psi, which should be more than enough...plus much less expensive.
Any suggestions apprecitated BH |
Joe Bob |
Jun 12 2003, 08:02 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
What temp you run at is the function of a thermostat. Running w/o one can damage the cooler on start up by hitting a slug of cold oil at high pressure into the cooler.
Running at less than optimum operating temps/short trips will allow sludge to build up in the engine.... A cooler will keep an engine cooler LONGER at high speeds/spirited driving. It should NOT lower operating temps. |
Lo-Fi Version | Time is now: 19th May 2024 - 11:20 AM |
