age old master cylinder question, I have both - new |
TravisNeff |
Mar 11 2005, 04:50 PM
I swapped suspensions between cars, and I have a brand new 19mm master cylinder and found that the silver car has a brand new 17mm master cylinder. Brakes are stock, metal master pads.
I know that the 19mm will not improve braking performance, and will have a shorter pedal travel (along with more effort) than the 17mm. That said, if you had either to choose from with stock brakes - what would you choose? |
lapuwali |
Mar 11 2005, 05:10 PM
It's a feel issue. Some like one, some like the other. There's no right answer here. If you like the brakes as they are, leave them alone. If you want a firmer pedal, try the 19mm unit. All it takes is some time and brake fluid to do a swap.
TravisNeff |
Mar 11 2005, 05:27 PM
Damn, an answer that I figured I would hear. I guess I will shoot with the 19mm for giggles.
davep |
Mar 11 2005, 06:05 PM
914 Historian Group: Benefactors Posts: 5,143 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
If the 19mm has not been used, then put it away for a while until it is needed. Otherwise, I reccommend the 19mm.
Lo-Fi Version | Time is now: 17th May 2024 - 11:46 AM |
