Weber jet recommendation |
SKL1 |
Nov 22 2015, 09:32 PM
Senior Member Group: Members Posts: 1,602 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
2.0 with Webcam and Mallory distributor. Timing set and carbs synched, but really flat just off idle. Runs better when further up in the revs.
At 1800' in AZ. Currently: 40 IDF, 200 air correction, F11 emulsion tube, 115 main, 58 idle, 55 float bowl, 28 venturis TIA... |
Elliot Cannon |
Nov 23 2015, 01:33 AM
2.0 with Webcam and Mallory distributor. Timing set and carbs synched, but really flat just off idle. Runs better when further up in the revs. At 1800' in AZ. Currently: 40 IDF, 200 air correction, F11 emulsion tube, 115 main, 58 idle, 55 float bowl TIA... What size venturi? You might want to experiment with different venturi sizes. I also think those idle jets are too large. |
Lo-Fi Version | Time is now: 19th May 2024 - 06:33 PM |
