Weber jet recommendation |
SKL1 |
Nov 22 2015, 09:32 PM
Senior Member Group: Members Posts: 1,602 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
2.0 with Webcam and Mallory distributor. Timing set and carbs synched, but really flat just off idle. Runs better when further up in the revs.
At 1800' in AZ. Currently: 40 IDF, 200 air correction, F11 emulsion tube, 115 main, 58 idle, 55 float bowl, 28 venturis TIA... |
Ansbacher |
Nov 23 2015, 06:08 AM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
In my experience with Webers and Dellortos, a flat stumble off idle is usually cured with smaller venturis (32s in your case) and a liberal dose of gas via the pump jets (crank 'em up). I think your idle jet size is fine- 60 is usually nominal for a 2.0L.
Ansbacher |
Lo-Fi Version | Time is now: 19th May 2024 - 12:16 PM |
