Weber jet recommendation |
SKL1 |
Nov 22 2015, 09:32 PM
Senior Member Group: Members Posts: 1,602 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
2.0 with Webcam and Mallory distributor. Timing set and carbs synched, but really flat just off idle. Runs better when further up in the revs.
At 1800' in AZ. Currently: 40 IDF, 200 air correction, F11 emulsion tube, 115 main, 58 idle, 55 float bowl, 28 venturis TIA... |
rhodyguy |
Nov 23 2015, 07:51 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Where do you have the air-bypass screws set? With 40mm the throttle plates should be @ 28mm unless the carbs have been worked over. Confirm the size.
Lo-Fi Version | Time is now: 17th May 2024 - 03:38 AM |
