914/LS vs 914/6 |
914/LS vs 914/6 |
Cracker |
Nov 24 2015, 08:42 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
The first video shows a couple laps running behind the 914/6/3.0 (SixAddict) of a good friend. The longer part shows a little more solo action...man these cars are fun!
Second Day after changes (1 lap only) - amazing balance in the car! https://youtu.be/NhHMaa0_R5o https://www.youtube.com/watch?v=NhHMaa0_R5o https://youtu.be/LfFdP8GnXiQ (12+ minutes) https://www.youtube.com/watch?v=LfFdP8GnXiQ https://youtu.be/9Te6GScwxek (3 minutes) https://www.youtube.com/watch?v=9Te6GScwxek The GT3 Cup is faster everywhere but still allot of fun to (try) keep up with. I might be a smidgen faster down the straights - barely at best. Tony |
messix |
Nov 26 2015, 03:30 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
find what the caster is set at. i bet its pretty low and more would give you a better on center feel and reduce the "twitchy" feel at speed.
some a/x set ups dont use much caster to reduce steering effort. |
Cracker |
Nov 26 2015, 03:47 PM
find what the caster is set at. i bet its pretty low and more would give you a better on center feel and reduce the "twitchy" feel at speed. some a/x set ups dont use much caster to reduce steering effort. Thanks for the tip. Please define, in your words "low caster and more caster" please? I understand caster as positive and negative. Please advise. Chris Foley was telling me the same thing yesterday. I'll try that too. Argh! Just found I busted a rear shock! Ain't race cars full of fun... Tony |
r_towle |
Nov 26 2015, 06:06 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
find what the caster is set at. i bet its pretty low and more would give you a better on center feel and reduce the "twitchy" feel at speed. some a/x set ups dont use much caster to reduce steering effort. Thanks for the tip. Please define, in your words "low caster and more caster" please? I understand caster as positive and negative. Please advise. Chris Foley was telling me the same thing yesterday. I'll try that too. Argh! Just found I busted a rear shock! Ain't race cars full of fun... Tony That could explain the squirrelly behavior you described. Stu, front tire rubs at lower rear against inner fender at the bottom. Lock to lock...with fat tires. |
Cracker |
Nov 26 2015, 06:14 PM
LOL. It felt better today WITH the blown shock. I did take it out for about 20 minute spirited drive this morning. Later in the day, for the first time, I found a small puddle of oil directly under the shock. I must have some binding on the raised shock mounts. Will fix...will be at track in 8 days!!!
Tony That could explain the squirrelly behavior you described. |
Lo-Fi Version | Time is now: 10th May 2024 - 04:48 AM |
