Sound Deadening Options? |
ThinAir |
Nov 25 2015, 04:16 PM
Best friends Group: Members Posts: 2,531 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
This is me, picking up my freshly repainted 914 from PMB Performance.
Now that it's home, it's time to start putting things back together. I'm looking for sound deadening solutions for the floor and interior back panel. I'm planning on keeping the interior back panel, but figured this would be a good time to enhance it with some sound deadening capability. My searches haven't been very successful. I'd appreciate it you guys could offer some advice or point me to previous threads on the subject. |
Cairo94507 |
Nov 25 2015, 04:20 PM
Michael Group: Members Posts: 9,703 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I have a roll of Dynamat for my car when it comes together. If I recall it is about 1/8" thick of a semi-sticky black tar-like substance with a heavy foil backing. No odor no glue required. Just cut and using a smallish roller lay it out and roll it nice and smooth and flat. I like to color and the paint job looks to be top drawer.
gfg3 |
Nov 25 2015, 04:24 PM
Never Too Old Group: Members Posts: 117 Joined: 5-January 15 From: Southern Virginia Member No.: 18,295 Region Association: None |
I have a roll of Dynamat for my car when it comes together. If I recall it is about 1/8" thick of a semi-sticky black tar-like substance with a heavy foil backing. No odor no glue required. Just cut and using a smallish roller lay it out and roll it nice and smooth and flat. I like to color and the paint job looks to be top drawer. (IMG:style_emoticons/default/agree.gif) I've used Dynamat in several cars; most recently my 914 and '61 TBird resto. A little pricey, but good stuff. George |
aircooledtechguy |
Nov 25 2015, 04:36 PM
I've used FatMat on several cars over the years with terrific results. It's virtually the same as Dynamat Extreme without the high price.
Andyrew |
Nov 25 2015, 04:37 PM
I have these two options on my list.
Sound deadener (Heavy) 50 Sq Ft Noico Self-adhesive Foil & Butyl Mat 50 Mil (Same basic product as Dynomat, however much cheaper and in easily workable squares) NOTE: They do sell this in 80 mil, but state that the 50mil is the best weight to results. http://www.amazon.com/gp/product/B00URR4O5..._dp_o_pC_nS_ttl Heat/sound barrier (Light) EZ Cool Automotive Insulation http://www.lobucrod.com/ Basically i'll use the Sound deadener sparingly on large flat panels and over gaps to help deaden the tinny noises. I will cut small strips and place them on every piece of metal to make it more "heavy". From there I will use the heat/sound barrier (lightweight) over that and create a full barrier as this will be my total seal, doubled up at the engine firewall. |
76-914 |
Nov 25 2015, 04:49 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,485 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Looks very nice Ernie. (IMG:style_emoticons/default/smilie_pokal.gif)
ThinAir |
Nov 25 2015, 04:55 PM
Grelber |
Nov 25 2015, 05:24 PM
Insert favorite Don Rickles joke here. Group: Members Posts: 690 Joined: 30-May 06 From: McKinney, Texas Member No.: 6,107 Region Association: Southwest Region |
+1 on the FatMat. A lot cheaper than DynaMat and just as good.
BIGKAT_83 |
Nov 25 2015, 05:29 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
I used a 50sq ft roll of 80mil on my 914. Made a big difference . Bob |
AZ914 |
Nov 25 2015, 05:31 PM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
I've used FatMat on several cars over the years with terrific results. It's virtually the same as Dynamat Extreme without the high price. (IMG:style_emoticons/default/agree.gif) I bought FatMat a few years back, cheaper than Dynamat. |
Shadowfax |
Nov 25 2015, 06:20 PM
Show us the meaning of haste Group: Members Posts: 509 Joined: 19-January 15 Member No.: 18,340 Region Association: South East States |
Another vote here for Fatmat.
Nov 25 2015, 07:25 PM
Custom Member Group: Members Posts: 24,560 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Lots of good info here and online.
My two cents. Sound deadening is about stopping both sound waves and vibration. Certain materials stop certain sound waves. Product like dynamat at rubber-foil which blocks two types of sound waves. It also builds up the thickness of the metal to reduce vibration. I would suggest a multi prongs approach. Ceramic spray on sound deadened on the engine bay side.( lizard skin is on product) 1/2 inch foil faced mat on the engine bay side (914 rubber has that) Dynamat on the inside. Then both blocked more types of sound waves, but reduced vibration twice. After all of that, the window is really loud. A double pain would fix that.. In the end, a loud stereo or earplugs work really well. |
Elliot Cannon |
Nov 25 2015, 07:36 PM
I wear these on the highway when I have the roof off and the windows down (which is usually all the time). Really cuts down on the fatigue factor on long trips.
shoguneagle |
Nov 25 2015, 08:43 PM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
Hi Ernie,
Just had to say hello and the car does look great. It has been a couple of years since we moved to Oregon. I have used Dynamite and the only thing is that it is expensive; I believe I will go the Fatmate or what Andyrew suggests. I personally want to stay away from the spray ons since over time they appear to collect rust. Underneath I have used rubberized adhesive paint. Again, the car looks great. Steve Hurt |
ThinAir |
Nov 25 2015, 11:12 PM
I would suggest a multi prongs approach. Ceramic spray on sound deadened on the engine bay side.( lizard skin is on product) 1/2 inch foil faced mat on the engine bay side (914 rubber has that) Dynamat on the inside. Even if it would be helpful, no treatment on the engine side for me. I just finished paying to fix rust in the firewall so we're not going there again. I have pretty reasonable expectations of how quiet a 914 can be so I think I'll be fine with interior treatments only. |
Nov 26 2015, 10:02 AM
Earplugs, like Elliot said, work wonders, especially on the highway next to trucks.
Rich |
saigon71 |
Senior Member Group: Members Posts: 1,995 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Your car looks great! (IMG:style_emoticons/default/beerchug.gif)
I went with Fat Mat Rattle Trap and installed an aftermarket heat/noise pad from 914 rubber (that won't hold water) on the engine side of the firewall. I am very happy with the noise level in my teener: http://www.amazon.com/FatMat-Self-Adhesive...rds=rattle+trap |
matthepcat |
Nov 26 2015, 10:37 AM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
I suggest not one huge sheet on the floor boards. Leave the channels on the floors open, so if moisture collects in them, it can dry out.
xperu |
Nov 26 2015, 11:39 AM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
[quote name='ThinAir' date='Nov 25 2015, 04:16 PM' post='2269580']
This is me, picking up my freshly repainted 914 from PMB Performance. Now that it's home, it's time to start putting things back together. I'm looking for sound deadening solutions for the floor and interior back panel. I'm planning on keeping the interior back panel, but figured this would be a good time to enhance it with some sound deadening capability. My searches haven't been very successful. I'd appreciate it you guys could offer some advice or point me to previous threads on the subject. I used the same as CAIRO (Dynamate), it is very easy to work with and dampens any vibration I was having. And yes my dynamite came with a handy roller. I used heavy 2" AC foil duct tape at the seams and it really came out nice. I like you choice of color. Nice car. Mike |
xperu |
Nov 26 2015, 11:42 AM
Lo-Fi Version | Time is now: 20th April 2024 - 01:30 AM |
