Waterlogged core engine, Engige underwater |
CatDaddy60 |
Nov 25 2015, 10:02 PM
Member Group: Members Posts: 99 Joined: 30-January 13 From: Austin Tx Member No.: 15,451 Region Association: Southwest Region |
I picked up a core engine from a junk yard and while I was doing enough of a teardown so that I could get it out of my truck I put a wrench on the alternator bolt to see if the engine would roll over. To my surprise the engine rolls over. Have any of you had experience with aan type 4 that's been underwater?
Spoke |
Nov 29 2015, 08:35 AM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I bought a 1.8L engine a while back with carbs. The engine had been sitting outside and was seized. I drained the oil to find about 3 quarts of water in the oil.
Removed the plugs and squirted oil and WD40 in all the plug holes. Slowly I started jogging the motor to free it. Got it to turn just a little bit. Then a little bit more and so on. Finally got it fully turning. Compression seemed ok so I put FI on it and ran the engine for the last 4 years. No problems. |
Lo-Fi Version | Time is now: 14th May 2024 - 11:12 AM |
