Waterlogged core engine, Engige underwater |
CatDaddy60 |
Nov 25 2015, 10:02 PM
Member Group: Members Posts: 99 Joined: 30-January 13 From: Austin Tx Member No.: 15,451 Region Association: Southwest Region |
I picked up a core engine from a junk yard and while I was doing enough of a teardown so that I could get it out of my truck I put a wrench on the alternator bolt to see if the engine would roll over. To my surprise the engine rolls over. Have any of you had experience with aan type 4 that's been underwater?
CatDaddy60 |
Nov 29 2015, 06:12 PM
After a teardown due to leaves and evidence of dirt and silt down the oil fill area I found a crack and a disintegrating cylinder in number 3 jug the crack ran the entire length of the cylinder and the is a chunk missing from the top of the cylinder. It looks like it went out of the cylinder past the valves but without cleaning up the head I can't see if the seat is OK. The rod bearings are not bad other than wear the crank journals will clean up but no rust just need cleaning cam same thing.
Lo-Fi Version | Time is now: 14th May 2024 - 03:14 AM |
