European Front Lenses, Conversion Kits |
CG-914 |
Nov 27 2015, 04:29 AM
Member Group: Members Posts: 323 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
A while Back I got this NOS front european turn signal leans kit.
Now I want to do it properly, and convert the bulbs from one to two. I saw this Kit on AA (and I like to avoid AA as much as possible) and I wonder, if it is any good? Also it is out of stockā¦ (IMG:style_emoticons/default/dry.gif) Are there better options? |
HaraldD |
Nov 27 2015, 04:35 AM
Member Group: Members Posts: 89 Joined: 23-November 08 From: Germany Member No.: 9,781 Region Association: Germany |
sfrenck |
Nov 27 2015, 07:10 AM
Member Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region |
Camp914.com has the kit .for $30
JmuRiz |
Nov 27 2015, 07:37 AM
914 Guru Group: Members Posts: 5,425 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
You can post a WTB ad, I'm sure some people (me included) have sets of that light kit they aren't going to use. We buy parts and change our minds as our project changes direction over the years.
Geezer914 |
Nov 27 2015, 07:49 AM
Geezer914 Group: Members Posts: 1,393 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
EdwardBlume |
Nov 27 2015, 08:11 AM
Spoke's LEDs is a good option too....
CG-914 |
Nov 27 2015, 09:04 AM
Thanks for all the links and suggestions. I will be doing it at Christmas...
76-914 |
Nov 27 2015, 09:28 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
SKL1 |
Nov 27 2015, 09:40 AM
Senior Member Group: Members Posts: 1,597 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
If Spoke makes them again that is the best. The kit like Camp and AA sells is marginal. I have a set I didn't use and would give it away free for shipping and that would be next to nothing...
Garland |
Nov 27 2015, 10:08 AM
Restoration Fanatic Group: Members Posts: 1,328 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
Martin Baker |
Nov 27 2015, 10:26 AM
I just heard I sold my cars! Group: Members Posts: 1,140 Joined: 11-February 03 Member No.: 290 Region Association: Northern California |
porschetub |
Nov 27 2015, 11:24 AM
If Spoke makes them again that is the best. The kit like Camp and AA sells is marginal. I have a set I didn't use and would give it away free for shipping and that would be next to nothing... Correct these kits are disappointing,a poor fit into the stock housings,joins in the wiring that make them hard to run, I also found them not very bright and changed to larger lamps which was an improvement. Had I known I would have bought the metal housing ones on German ebay,they appear to be more like the originals (IMG:style_emoticons/default/confused24.gif) . |
CG-914 |
Dec 29 2015, 10:04 AM
Hank914 |
Dec 29 2015, 12:17 PM
Member Group: Members Posts: 389 Joined: 7-April 14 From: CA and OR Member No.: 17,215 Region Association: None |
So after you all gave me such great advise, I just decided to make it myself... Here are some Pictures: I like your DIY ingenuity but what is that little metal thingy with the pointed ends? Have not seen them since the '70s... Maybe came in the tool kit? Is your bulb as bright as the Spoke LED solution? I need to do what you are doing. Thanks for the thread! |
michael7810 |
Dec 29 2015, 12:54 PM
Senior Member Group: Members Posts: 1,080 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
Wonder how much of a difference it would make if you wrapped the new sheet metal with foil?
rgalla9146 |
Dec 29 2015, 12:56 PM
So after you all gave me such great advise, I just decided to make it myself... Here are some Pictures: I like your DIY ingenuity but what is that little metal thingy with the pointed ends? Have not seen them since the '70s... Maybe came in the tool kit? Is your bulb as bright as the Spoke LED solution? I need to do what you are doing. Thanks for the thread! A compass ? Not included in a tool kit |
bandjoey |
Dec 29 2015, 03:31 PM
bandjoey Group: Members Posts: 4,923 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Model shops sell 'real' chrome paint for more shine
CG-914 |
Dec 30 2015, 08:41 AM
So after you all gave me such great advise, I just decided to make it myself... Here are some Pictures: I like your DIY ingenuity but what is that little metal thingy with the pointed ends? Have not seen them since the '70s... Maybe came in the tool kit? Is your bulb as bright as the Spoke LED solution? I need to do what you are doing. Thanks for the thread! It is a compass. I got it out of my dads architecture stuff, I'm sure he has it till the 70s... They are pretty bright right know, it is galvanised sheet matel so it reflects the light pretty good. |
Spoke |
Dec 30 2015, 08:59 AM
If Spoke makes them again that is the best. I should have more front boards in Feb. We're making rear boards now. The board shown below turns off the running light when the turnsignal is active to provide more contrast so others will see the turnsignal better. Attached thumbnail(s) Attached image(s) |
SKL1 |
Dec 30 2015, 09:07 AM
Spoke's boards are the easiest and best way to go. I've got both styles on my 914's. The euro style works great without that cheap plastic divider that's in the various kits.
Just need his rear boards for my '73- didn't order them in time on his last run. |
Lo-Fi Version | Time is now: 5th May 2024 - 02:43 AM |
