exhaust ports and pushrod tubes, need to poll the World Brain Trust |
iankarr |
Nov 27 2015, 01:33 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hi Guys,
Making good process on getting the engine cleaned up and tightened so it leaks less (IMG:style_emoticons/default/wink.gif). I hadn't planned on removing a heat exchanger, but it was the easiest way to rotate the engine on the stand so I could have easier access to the pushrod tubes. Happy to report that the HE nuts came off pretty easily. But when I looked in the ports, the copper gaskets weren't as clean as I'd expect. Would appreciate it if the brain trust would take a look. I have new copper gaskets, and was thinking I'd "true" up the ports on the HE before replacing. Any tips/thoughts on that? Also, I've read a bunch o' threads on changing the pushrod tube seals, but would appreciate any real-world suggestions. Finally...is it OK to work on the motor upside-down on the stand? All oil has been thoroughly drained. Anything to watch out for there? Thanks! |
TheCabinetmaker |
Nov 27 2015, 01:52 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I always flatten the headers with a very large file. Use a marker or paint on the edge of the pipes and file both together with long strokes till the paint is gone. Anneal the new gaskets with a torch to soften them. A dowel rod with some sandpaper glued to the end will help to clean up the ports on the head.
If the push rods aren't leaking, I wouldn't disturb them. |
Lo-Fi Version | Time is now: 20th May 2024 - 11:30 AM |
