Converting from Fuel Injection to Carbs, Need Fuel Distrabution help |
Robin914-4 |
Nov 28 2015, 12:06 PM
Newbie Group: Members Posts: 10 Joined: 28-November 15 From: Statesboro, Georgia Member No.: 19,419 Region Association: South East States |
Hey Everybody. I have been searching for an hour with no luck. I have a 1976 914/4 that I have converted over to 44mm Empi's. Now I am setting up the fuel system, new low pressure pump, stainless lines, presure regulator, etc. what I can't figure out is what to do with the extra line I have on the fuel tank. Should I cap it? Vent it? I did run both stainless line back to the engine bay so I could t them in or what ever. I just need some guidance.
Thanks in advance. Robin |
jvmarino |
Apr 10 2016, 01:31 PM
Member Group: Members Posts: 81 Joined: 22-March 09 From: Baltimore Member No.: 10,188 Region Association: None |
Another fuel tank related item you may want to consider when running carbs is a vacuum relief. I never had one on mine and then one day after a long drive I had fuel starvation. I opened fuel filler to confirm there was fuel in tank and heard a large rush of air in tank and sounds of the metal fuel tank relaxing from being under strong vacuum. I later found some posts about this and added a relief valve on my car. I am sure some others that have more experience can provide their thoughts.
Jim |
Lo-Fi Version | Time is now: 26th May 2024 - 05:53 PM |
