Converting from Fuel Injection to Carbs, Need Fuel Distrabution help |
Robin914-4 |
Nov 28 2015, 12:06 PM
Newbie Group: Members Posts: 10 Joined: 28-November 15 From: Statesboro, Georgia Member No.: 19,419 Region Association: South East States |
Hey Everybody. I have been searching for an hour with no luck. I have a 1976 914/4 that I have converted over to 44mm Empi's. Now I am setting up the fuel system, new low pressure pump, stainless lines, presure regulator, etc. what I can't figure out is what to do with the extra line I have on the fuel tank. Should I cap it? Vent it? I did run both stainless line back to the engine bay so I could t them in or what ever. I just need some guidance.
Thanks in advance. Robin |
ClayPerrine |
Apr 10 2016, 04:50 PM
Life's been good to me so far..... Group: Admin Posts: 15,470 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The FI will run smoother and more reliably on a 914. The carb linkage is affected by the engine heating and cooling, and the carbs get out of sync easily. So unless you have a big motor with lots of cam, the FI works better. That being said, if you cant find your set of cooling flaps, I have a LOT of them. You can have one set for the cost of shipping. |
Robin914-4 |
Jun 29 2016, 06:54 PM
(IMG:style_emoticons/default/agree.gif) The FI will run smoother and more reliably on a 914. The carb linkage is affected by the engine heating and cooling, and the carbs get out of sync easily. So unless you have a big motor with lots of cam, the FI works better. That being said, if you cant find your set of cooling flaps, I have a LOT of them. You can have one set for the cost of shipping. Wish I would have seen this earlier. I just got a set off of eBay and that set me back 75 bucks. As far as the EFI, I sold it because I was lead to believe that since I put a big bore kit in it that the EFI being a closed system wouldn't work. Also I am very old school and am much better with carbs. |
Lo-Fi Version | Time is now: 18th May 2024 - 07:51 PM |
