Converting from Fuel Injection to Carbs, Need Fuel Distrabution help |
Robin914-4 |
Nov 28 2015, 12:06 PM
Newbie Group: Members Posts: 10 Joined: 28-November 15 From: Statesboro, Georgia Member No.: 19,419 Region Association: South East States |
Hey Everybody. I have been searching for an hour with no luck. I have a 1976 914/4 that I have converted over to 44mm Empi's. Now I am setting up the fuel system, new low pressure pump, stainless lines, presure regulator, etc. what I can't figure out is what to do with the extra line I have on the fuel tank. Should I cap it? Vent it? I did run both stainless line back to the engine bay so I could t them in or what ever. I just need some guidance.
Thanks in advance. Robin |
Gunn1 |
Jul 2 2016, 08:50 AM
Senior Member Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
Fuel Injection is definitely the way to go if your going to stay stock or almost stock as many will attest to on the site......
There are many great sites that will help with identifying the parts you will need and more importantly what you will need as a complete system to work. The ECU/brain, injectors, TPS and the other items are not necessarily interchangeable. Identification has more to do with your engines displacement. Good Luck! |
Lo-Fi Version | Time is now: 26th May 2024 - 05:55 PM |
