Need a new transmission...so, what gear ratios?, 2.7L |
billh1963 |
Nov 28 2015, 05:40 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
My '72 with a 2.7 six is back.
The engine is running great. However, the gear box is so shitty it's not even worth driving. I've owned a lot of 914's and never had a gearbox so bad. I tried to go for a drive today and made it about 2 miles before I gave up and headed home. I felt like leaving it on the side of the road for the trash collector. Seriously,it's that shitty. The couple times I found second gear it wanted to crunch so I think I'm going to just rebuild it (of course all the shifter bushings and everything related to shifting will be gone through and updated). So, I've looked at several threads and even found some charts of gear ratios/rpm/speeds. For those with a 2.7 or 3.0, did you use the stock ratios? Are you happy with that? What would you change? I'm thinking of changing fifth gear to cruise around 2800-3000 rpm at 70mph. Will that give me enough fan speed to keep the oil cool? I do NOT have an external oil cooler. Tires size is 205/55-16 Any input is appreciated. Thank you |
fixer34 |
Nov 28 2015, 07:31 PM
Senior Member Group: Members Posts: 1,085 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
My '72 with a 2.7 six is back. The engine is running great. However, the gear box is so shitty it's not even worth driving. I've owned a lot of 914's and never had a gearbox so bad. I tried to go for a drive today and made it about 2 miles before I gave up and headed home. I felt like leaving it on the side of the road for the trash collector. Seriously,it's that shitty. The couple times I found second gear it wanted to crunch so I think I'm going to just rebuild it (of course all the shifter bushings and everything related to shifting will be gone through and updated). So, I've looked at several threads and even found some charts of gear ratios/rpm/speeds. For those with a 2.7 or 3.0, did you use the stock ratios? Are you happy with that? What would you change? I'm thinking of changing fifth gear to cruise around 2800-3000 rpm at 70mph. Will that give me enough fan speed to keep the oil cool? I do NOT have an external oil cooler. Tires size is 205/55-16 Any input is appreciated. Thank you According to the RPM/MPH graphs in the back of my -6 owner manual, 70mph comes on right around 3000rpm, so a stock -6 trans should be fine. |
Lo-Fi Version | Time is now: 25th May 2024 - 01:25 PM |
