FS: Parting Out 1974 914, Will be in LA area Dec 4-6! |
mrihop |
Nov 30 2015, 12:10 PM
Member Group: Members Posts: 265 Joined: 6-November 04 From: Pahrump, NV Member No.: 3,068 Region Association: None |
Hey guys! Ran across this car and picked it up thinking I would build a race car out of it. However, I am out of space in the garage and time to work on it. The driver side was hit pretty hard, so the door and rear fender are pretty much toast. The firewall was tweaked as well. The car is fairly complete including a "running" 1.8 wigh a single carb. The car sat for years after the accident, and the gas was never taken care of. The heads look new on the engine, and I did run the car around the block, ot drove straight, and the trans shifts pretty well. The remaining fenders look decent.
I would be interested in selling the car complete, or part it out depending on the response from this thread. FYI, it is the Top Gear US car for those of you that have seen that thread or episode. Car is in Pahrump, NV, and would prefer to see it gone ASAP, but overall it is rough and would be much better off as a parts car, so tell me what you guys want! (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/driving.gif) Attached thumbnail(s) |
Luke M |
Nov 30 2015, 01:54 PM
Senior Member Group: Members Posts: 1,371 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Hi there,
Are you planning on cutting this car up? If so, hows the pass side long from the front fender to the rear shock tower. Let me know. Thanks, |
mrihop |
Nov 30 2015, 02:04 PM
Hi there, Are you planning on cutting this car up? If so, hows the pass side long from the front fender to the rear shock tower. Let me know. Thanks, Not ready to cut up the car yet, but the long has surface rust in areas that I can see, but the car overall is solid. Typical hell hole issues, but minimal. Send a pic of exactly what you want, and the cutting starts in about 2 weeks if someone doesn't pick up the entire chassis. |
Luke M |
Nov 30 2015, 02:17 PM
Hi there, Are you planning on cutting this car up? If so, hows the pass side long from the front fender to the rear shock tower. Let me know. Thanks, Not ready to cut up the car yet, but the long has surface rust in areas that I can see, but the car overall is solid. Typical hell hole issues, but minimal. Send a pic of exactly what you want, and the cutting starts in about 2 weeks if someone doesn't pick up the entire chassis. This is the metal section that I'm looking for. As long as it's in good shape and not too much rust damage. Cut from the r/r shock tower forward to the outer fender area ( just like I have outlined it in the pic ) . Obviously I'd like to see some pic of the area prior to cutting just to see if it's something that I can work with. Thanks, Attached image(s) |
Luke M |
Nov 30 2015, 02:26 PM
Hi there, Are you planning on cutting this car up? If so, hows the pass side long from the front fender to the rear shock tower. Let me know. Thanks, Not ready to cut up the car yet, but the long has surface rust in areas that I can see, but the car overall is solid. Typical hell hole issues, but minimal. Send a pic of exactly what you want, and the cutting starts in about 2 weeks if someone doesn't pick up the entire chassis. This is the metal section that I'm looking for. As long as it's in good shape and not too much rust damage. Cut from the r/r shock tower forward to the outer fender area ( just like I have outlined it in the pic ) . Obviously I'd like to see some pic of the area prior to cutting just to see if it's something that I can work with. Thanks, This is a pic of the drivers side ( just using as a reference for cutting ) . Attached image(s) |
Lo-Fi Version | Time is now: 15th May 2024 - 01:14 AM |
