Impeller Housing Disassembly: 2 Frozen Screws |
stephestrad |
Dec 1 2015, 01:13 AM
Newbie Group: Members Posts: 18 Joined: 28-February 13 From: Berkeley, CA Member No.: 15,596 Region Association: Northern California |
I'm attempting my first partial engine disassembly and I have run into a stumbling block: Two of the screws in the front of the impeller housing are solidly frozen. Additionally, the slots of the heads are starting to strip out.
Removal attempts so far: 1. Soaked them overnight in WD-40. 2. Several raps with a hammer. (Normal hammer, struck the screwdriver handle, not the screw directly.) 3. Heated them with a propane torch (3 or 4 times, 30-60 seconds each). - I tried with and without squirts of water post-heating. - Before and after the heat, sprayed with PB Blaster. - Was the heat a bad idea, given the magnesium housing? The screws are still stubbornly in place. For what it's worth, the engine is horizontal, so the WD-40 and BP Blaster don't have the benefit of gravity to helping pull them into the threads. Help!!! (IMG:style_emoticons/default/sad.gif) |
stephestrad |
Dec 5 2015, 10:51 PM
Victory!!! (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif)
I ended up heating each screw for 5 minutes, soaking with PB Blaster, then inching out with the impact driver. Phew! I was stressing about that one. Btw, turns out a size 12-14 slotted driver bit (found at Ace Hardware) fits the cheese head screws very well. Thanks all for you help! |
Dave_Darling |
Dec 6 2015, 11:31 AM
Lo-Fi Version | Time is now: 24th May 2024 - 04:39 PM |
