front rubber bumper spacer, front rubber bumper spacer |
9fourteen14 |
Dec 5 2015, 11:36 AM
PORSCHE LUVA Group: Members Posts: 135 Joined: 5-July 15 From: boston Member No.: 18,920 Region Association: North East States |
tweet |
Dec 5 2015, 11:40 AM
Member Group: Members Posts: 200 Joined: 25-February 13 From: South Florida Member No.: 15,579 Region Association: South East States |
It is held on with two flared rubber plugs that are cast as part of the spacer itself. Most of the time they will break off when you remove them. You could try to compress them with some needle nose pliers and push them through. Or, just leave them in place and work around them. |
9fourteen14 |
Dec 5 2015, 12:12 PM
It is held on with two flared rubber plugs that are cast as part of the spacer itself. Most of the time they will break off when you remove them. You could try to compress them with some needle nose pliers and push them through. Or, just leave them in place and work around them. hey Tweet I am going to have the bumper powder coated so need to take them off thanx for the tip and interest. I really do appreciate it |
Mikey914 |
Dec 5 2015, 12:26 PM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Glycerin - Lube it up they'll pop right out.
9fourteen14 |
Dec 5 2015, 03:12 PM
Lo-Fi Version | Time is now: 17th May 2024 - 04:58 PM |
