Ditron 812D D-Jetronic Tester, Searching for instruction |
nordfisch |
Dec 11 2015, 07:25 PM
Member Group: Members Posts: 86 Joined: 11-December 15 From: Germany Member No.: 19,451 Region Association: None |
Hi,
this forum was recommended to me... and this is really a great place for guys like me, interested in the D-Jetronic system. We have a forum in Germany, German and English language "oldtimer.tips", too. We are more conservative than you are, mostly just trying to find out everything about the system and how to repair the components. We are hobbyists mostly MB, but also BMW, VW, Opel, Porsche, Renault, Citroen, Lancia... all the car brands D-Jetronic was installed in. I by myself designed a tool for re-adjusting the trigger points to the original values. Simple to be rebuilded if you have a lathe - I will send you a figure on request. Now my own request: Does anyone here own a Ditron 812D tester, too? I own such a device, but without any instruction. It once came to Europe with the instruction, but it got lost. I bought the Ditron some months ago on ebay from switzerland - the seller told me he had bought it many years ago at ebay USA. It's no problem for me to understand and use the basic testing functions, but this tester is not only a testing - but an ECU-simulating device. I don't really need the Ditron 812D to diagnose or optimize my car - I own some other testers. But because the D-Jetronic-system is my hobby, I would like to understand the additional function, i.e. what the manufacturer intended the user to test / adjust with it. Hope that someone still has the instruction for the tester... My tester has serial #119 - don't know how many were built at all. P.B. "Brad" Anders described the tester: D-Jetronic Testers as being similar to the Janbo Model 112 he described more detailed. Does anyone own the tester / the instruction? Please help... Regards Norbert |
JeffBowlsby |
Jan 24 2016, 04:24 PM
914 Wiring Harnesses Group: Members Posts: 8,527 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Thank you Norbert, I will contact Volker that when I get a chance,, he seems very knowledgeable. I was aware of the other pressure sensor types, but being a 914 guy, the only one I had the most exposure to is what you refer to as the type II MPS.
nordfisch |
Jan 25 2016, 12:04 AM
Thank you Norbert, I will contact Volker that when I get a chance,, he seems very knowledgeable. I was aware of the other pressure sensor types, but being a 914 guy, the only one I had the most exposure to is what you refer to as the type II MPS. Yes, Jeff - you are absolutely right. I checked this in the meantime- only 'Type II'-sensors in various versions have been used originally in the 914. Maybe some 914 have installed the TPS with the full-load-switch, but this is not connected then. Only four wires towards TPS in a five-poled housing perhaps. Regards Norbert |
Lo-Fi Version | Time is now: 3rd June 2024 - 06:44 AM |
