welding galvanized metal, ??? |
type11969 |
Mar 14 2005, 09:48 AM
Senior Member Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States |
I have some square pieces of sheet metal that I bought at a FLAPS, they seem to be galvanized (shiny and don't rust). I've formed one into an angle and was going to weld it into my long for some rust repairs, but I believe I've read that welding galvanized steel isn't good. Couldn't find anything with the search feature though. Anyway, does anyone have any information about welding galvanized? Is it not as strong as un-galvanized? The non-rusting nature of the stuff certainly seems to be a big benefit.
I've practiced welded with the stuff and I've made some strong (but ugly) welds. -Chris |
McMark |
Mar 14 2005, 09:55 AM
Galvanized welds like crap. You can get it in there and make it work. But it welds like crap. (IMG:http://www.914world.com/bbs2/html/emoticons/barf.gif)
Watch out for the fumes too. They're bad fur ya'. |
spunone |
Mar 14 2005, 09:58 AM
Senior Member Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
Sand off area of Galv before welding since the gas is poisonous I think its a phosgene gas not good
Rhodes71/914 |
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
Like Mark said, you DO NOT want to breath those fumes.
Eric_Shea |
Mar 14 2005, 10:29 AM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
grind it all of and weld away... hold your breath (IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif)
type11969 |
Mar 14 2005, 10:45 AM
Hmmm, looks like I might have poisoned myself yesterday, great. I think I will bag using this galvanzied stuff and hack up the shitty 914 hood that I have for replacement metal.
Thanks for the help. -Chris |
TravisNeff |
Mar 14 2005, 10:59 AM
I used galvanized wire on my chicken coupe project. I will agree with others, stay away from welding it. The fumes are very toxic and you will feel sick for a couple days afterwards. If you must use it, use serious ventilation - like a fan even if you are doing it outside.
It does suck welding it, as soon as the arc hits the zinc or whatever coating it is, it vaporizes (the metal) very quickly. The only advice that I can say is to start your arc on the old metal and slowly work your way to the galvanized piece, the heat will slowly burn off the part and at that point you can get a decent weld. Or grind the crap out of both sides of that panel to remove the galvanizing along your weld path. |
Lo-Fi Version | Time is now: 6th May 2024 - 02:52 PM |
