Honda V-6 in the 914, engine options |
tomrev |
Dec 19 2015, 03:04 PM
Member Group: Members Posts: 231 Joined: 25-February 14 From: N. Mich. Member No.: 17,037 Region Association: None |
Thought I'd put up a few photo's of my current 914 project. I had a six from 1984 to 1998; started with the 2.0 T, then a 2.0S, to a 2.7, and finally a 3.0, with RSR pistons, Solex cams and a few other tweaks. She was a blast to drive, and I drove her to work, and vintage raced her for many years. About six years ago the 914 urge returned, and I built a few V8 cars, one with a LS, the other with old school SBC. They were both cool, and super fast, but just didn't sound right, so I began thinking of another six. Once the price shock passed, I knew it wasn't going to be a Porsche six, and started learning about some alternatives, and settled on the Honda 3.5 V6 from the Pilot, etc. They are all aluminum, variable valve timing, compact, light, and dirt cheap, and make around 250HP, and Ft. Lbs, a nice level for a 914. And happily, Kennedy makes the adapter kit, so that part is out there.
After a trip to the junk yard to look at, and measure, it seemed close enough to bring one home, and really start playing with it. I am aware of one other 914 with this engine in it, but it's a solo car, with out a trunk floor, etc., so one problem fitting it in. I have a nice 20K original car, too nice to start cutting up, so if the engine wouldn't go in, I'd give it up. (The car was a V8 car almost from new, don't panic!). The engine is very compact, but the intake spreads out over the gearbox, and would stick way into the trunk. Fortunately, the intake can be flipped 180 deg., and by cutting off the throttle body, and re-welding it onto the side, the engine becomes nice and workable. It is a tight squeeze, but fits almost like it was designed to be there. Attached thumbnail(s) |
EdwardBlume |
Dec 20 2015, 07:52 AM
Wow, what a mock up on boards! Can you spin plates on sticks too? (IMG:style_emoticons/default/av-943.gif)
tomrev |
Dec 20 2015, 08:57 AM
Wow, what a mock up on boards! Can you spin plates on sticks too? (IMG:style_emoticons/default/av-943.gif) Nice eh? Had to start somewhere, so i could think out the front engine mounts, but it was a SLOW process raising her up without losing control of the whole thing. Up until the end, it did not look good, like the shifter would be un-useable, etc., but after the last few inch's, suddenly the shifter was unshrouded, the engine lid shut, and the only body mods will be a small bubble cut, made in the forward trunk floor, for the thermostat housing, and the targa top will be able to fit as original, which I couldn't do with the Chevy installed. I could even re-use the Chevy spacers made to locate the trans rearward, by flipping them forward 180 deg., and still have a nice open area between the engine and firewall. Marking and cutting the trunk pocket will be next. |
Lo-Fi Version | Time is now: 19th May 2024 - 06:30 PM |
