Honda V-6 in the 914, engine options |
tomrev |
Dec 19 2015, 03:04 PM
Member Group: Members Posts: 231 Joined: 25-February 14 From: N. Mich. Member No.: 17,037 Region Association: None |
Thought I'd put up a few photo's of my current 914 project. I had a six from 1984 to 1998; started with the 2.0 T, then a 2.0S, to a 2.7, and finally a 3.0, with RSR pistons, Solex cams and a few other tweaks. She was a blast to drive, and I drove her to work, and vintage raced her for many years. About six years ago the 914 urge returned, and I built a few V8 cars, one with a LS, the other with old school SBC. They were both cool, and super fast, but just didn't sound right, so I began thinking of another six. Once the price shock passed, I knew it wasn't going to be a Porsche six, and started learning about some alternatives, and settled on the Honda 3.5 V6 from the Pilot, etc. They are all aluminum, variable valve timing, compact, light, and dirt cheap, and make around 250HP, and Ft. Lbs, a nice level for a 914. And happily, Kennedy makes the adapter kit, so that part is out there.
After a trip to the junk yard to look at, and measure, it seemed close enough to bring one home, and really start playing with it. I am aware of one other 914 with this engine in it, but it's a solo car, with out a trunk floor, etc., so one problem fitting it in. I have a nice 20K original car, too nice to start cutting up, so if the engine wouldn't go in, I'd give it up. (The car was a V8 car almost from new, don't panic!). The engine is very compact, but the intake spreads out over the gearbox, and would stick way into the trunk. Fortunately, the intake can be flipped 180 deg., and by cutting off the throttle body, and re-welding it onto the side, the engine becomes nice and workable. It is a tight squeeze, but fits almost like it was designed to be there. Attached thumbnail(s) |
mgp4591 |
Feb 24 2016, 03:10 PM
914 Guru Group: Members Posts: 5,374 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Sound clip indeed! I see you relocated your throttle body for clearance - nice job! Do you have any idle or running problems due to the internal EGR tube or the vacuum path dividers inside the manifold? Great conversion by the way!
tomrev |
Feb 24 2016, 03:29 PM
Sound clip indeed! I see you relocated your throttle body for clearance - nice job! Do you have any idle or running problems due to the internal EGR tube or the vacuum path dividers inside the manifold? Great conversion by the way! No, she idles perfect. I eliminated the EGR, and tapped and plugged all the EGR tubes/ports in all sections of the manifold. Without relocating the TB, (and flipping the intake 180 deg.), there was no way the engine would fit, without a lot of body/trunk mods, and the plan was to leave the car unmolested, as much as possible. It has been a super fun project, with lots of stuff to fab, and $$ stayed pretty low, at $2K total. I think the power level is well suited to the 901 box, as well. |
Lo-Fi Version | Time is now: 19th May 2024 - 03:52 PM |
