Car porn not 914 but related, hey it's all in the family, Unbelievable pictures |
Mikey914 |
Dec 21 2015, 10:57 AM
The rubber man Group: Members Posts: 12,668 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
A customer of mine in is doing a 67 912 resto from tub up. The early 912s had the same issues with rust we do and even has foam in them too (just like our 914s).
He used a company in Ohio to dip the car and dissolve the crud (he did scrape off the tar) ans ecoat the entire car. He did the doors 1st to see if he would like the results, and wow! Looks like new metal. Looks like Stoddard will be doing a full write up on this car at some point, but I was so impressed with the results that though I would share. Attached thumbnail(s) |
peteyd |
Dec 21 2015, 11:16 AM
Senior Member Group: Members Posts: 707 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
Dipping cars is something we never recommend. I have heard too many stories of people painting their car and then 3-5 years later it starts to bubble.
The problem is the acid, or whatever they use to dissolve the paint and crud, gets in between the layers of sheet metal where they were spot welded. Then leaches out slowly and causes bubbling. I also speak from experience. We had a bugeye sprite dipped and through out the restoration liquid was coming from the seems. but that's just my 2 cents. Hopefully your buddy got a good company that rinsed it thoroughly. Pete |
BillC |
Dec 21 2015, 08:54 PM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
Dipping cars is something we never recommend. I have heard too many stories of people painting their car and then 3-5 years later it starts to bubble. The problem is the acid, or whatever they use to dissolve the paint and crud, gets in between the layers of sheet metal where they were spot welded. Then leaches out slowly and causes bubbling. I also speak from experience. We had a bugeye sprite dipped and through out the restoration liquid was coming from the seems. but that's just my 2 cents. Hopefully your buddy got a good company that rinsed it thoroughly. Pete Doing a traditional dip on a car requires two extra steps that they never tell you about:
Otherwise, you'll have the exact problem you experienced -- chemical leaching out later and ruining the paint job. |
Lo-Fi Version | Time is now: 17th May 2024 - 09:41 AM |
