New wheel caps |
New wheel caps |
Cal |
Dec 22 2015, 12:37 PM
Senior Member Group: Members Posts: 614 Joined: 19-November 14 From: Philadelphia Member No.: 18,138 Region Association: North East States |
I need to replace the dinged fuch wheel caps on my 2.0L. I'd like to replace them with NOS but they're hard to find. Are the aftermarket caps currently available a close match that I can get by with until I find originals? If so who makes the best / most accurate?
Cal |
Jan 30 2016, 05:24 PM
I ended up purchasing ISP Fuch center caps and guess what.....way too tight and don't fit over the front grease caps. Hopefully I'll be able to return them. I selected these because the finish appeared better then the photos of the caps that 914R has on his website. Can anyone vouch for the finish of the 914R caps? The one mint condition original cap that I have has a mirror chrome finish when fully polished....the 914R caps appear to be a dull aluminum finish. Is this true and will they fit over the grease caps?
Mikey914 |
Jan 31 2016, 10:13 PM
The rubber man Group: Members Posts: 12,625 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I ended up purchasing ISP Fuch center caps and guess what.....way too tight and don't fit over the front grease caps. Hopefully I'll be able to return them. I selected these because the finish appeared better then the photos of the caps that 914R has on his website. Can anyone vouch for the finish of the 914R caps? The one mint condition original cap that I have has a mirror chrome finish when fully polished....the 914R caps appear to be a dull aluminum finish. Is this true and will they fit over the grease caps? Funny, When I 1st made them I had the same problem, but mine do fit once the machining was correct. Mine are a "dull" finish as we do a brite dip with a clear anodized finish to seal the finish. It 's possible to strip and polish them regardless of where you buy them. |
Cal |
Feb 1 2016, 07:48 PM
I ended up purchasing ISP Fuch center caps and guess what.....way too tight and don't fit over the front grease caps. Hopefully I'll be able to return them. I selected these because the finish appeared better then the photos of the caps that 914R has on his website. Can anyone vouch for the finish of the 914R caps? The one mint condition original cap that I have has a mirror chrome finish when fully polished....the 914R caps appear to be a dull aluminum finish. Is this true and will they fit over the grease caps? Funny, When I 1st made them I had the same problem, but mine do fit once the machining was correct. Mine are a "dull" finish as we do a brite dip with a clear anodized finish to seal the finish. It 's possible to strip and polish them regardless of where you buy them. Thanks Mark. I just placed the order for your caps.....I'm looking forward to receiving them! |
Lo-Fi Version | Time is now: 29th March 2024 - 06:45 AM |
