Door Panel Clips, How to re do..... |
jim_hoyland |
Dec 25 2015, 09:54 PM
Get that VIN ? Group: Members Posts: 9,302 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I installed the fiberglass door panels with the black door clips several years ago. Many have broke off and unusable; a simple replacement IIRC isn't possible because of the vinyl covering on the inside surface of the door panel.
Any thoughts on how I can get this reattached so it's firm ? |
Mikey914 |
Dec 26 2015, 02:07 AM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Actually they just turn in. Note the end is not a full circle. Easy to replace.
http://shop.914rubber.com/Porsche-914-Door...m?categoryId=-1 |
jim_hoyland |
Dec 26 2015, 07:27 AM
Actually they just turn in. Note the end is not a full circle. Easy to replace. http://shop.914rubber.com/Porsche-914-Door...m?categoryId=-1 Mine broke at their bases; can I remove them still ? |
skier2.0 |
Dec 26 2015, 08:43 AM
Newbie Group: Members Posts: 34 Joined: 30-May 14 From: United States Member No.: 17,422 Region Association: MidAtlantic Region |
Not exactly sure were you mean but just remove the broken part and twist the new ones in. They are not totally round so just start one edge and twist.
Mikey914 |
Dec 26 2015, 11:41 AM
Exactly,
You can remove by twisting and reinstall the new ones the same way. |
jim_hoyland |
Dec 26 2015, 03:05 PM
Got it, thanks; ordering ... (IMG:style_emoticons/default/smile.gif)
barefoot |
Dec 27 2015, 08:15 PM
Senior Member Group: Members Posts: 1,275 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Actually they just turn in. Note the end is not a full circle. Easy to replace. http://shop.914rubber.com/Porsche-914-Door...m?categoryId=-1 These that Mickey sells are on we time installation. you'll have to destroy them if you need to remove the panel. I found another source that are more like the OEM that can be backed out. I had mentioned this to Mickey, so perhaps he's re-designed his by now. |
jim_hoyland |
Dec 27 2015, 08:26 PM
Actually they just turn in. Note the end is not a full circle. Easy to replace. http://shop.914rubber.com/Porsche-914-Door...m?categoryId=-1 These that Mickey sells are on we time installation. you'll have to destroy them if you need to remove the panel. I found another source that are more like the OEM that can be backed out. I had mentioned this to Mickey, so perhaps he's re-designed his by now. Oh ? (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 03:14 PM |
