Good start for aluminum rear trailing arms??, things that make you go hmmmmmm :) |
Mueller |
Mar 15 2005, 12:09 PM
While doing a quick search on eBay, I came across these Boxster/996 rear suspension parts.....nice cast aluminum with the 5 bolt flange (with hubcentric ring) and bearings
Seems like it wouldn't be too difficult to use this as a base for making an aluminum or even a composite steel/aluminum trailing arm to help cut down on unsprung weight. eBay ad for rear hubs Attached image(s) |
Lo-Fi Version | Time is now: 21st May 2024 - 04:12 AM |
