Header sizing 914-6 |
mb911 |
Dec 27 2015, 02:21 PM
914 Guru Group: Members Posts: 6,854 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
So while my 914-6 oil tanks are being machined I going to start working through my header with heat exhanger design out of stainless.. I do not have non compete on these with m&k so that gives me design freedom.. However I will use similar design process as the m&k/ rarlyl8 design. So my question is 1.5" the most common size or allot of you using 1.625
Mark Henry |
Dec 28 2015, 08:27 AM
1-1/2" up to 2.7
1-5/8" or 1 3/4" for 3.0 and 3.2, stock I'd use the 1 5/8" and use the bigger for HP. But that said, although there would obviously be a bit of power loss, even a stock 3.2 runs fine on factory heat exchangers with are IIRC only about 1 3/8". |
Lo-Fi Version | Time is now: 20th May 2024 - 11:28 PM |
