Header sizing 914-6 |
mb911 |
Dec 27 2015, 02:21 PM
914 Guru Group: Members Posts: 6,851 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
So while my 914-6 oil tanks are being machined I going to start working through my header with heat exhanger design out of stainless.. I do not have non compete on these with m&k so that gives me design freedom.. However I will use similar design process as the m&k/ rarlyl8 design. So my question is 1.5" the most common size or allot of you using 1.625
Steve |
Dec 29 2015, 12:40 PM
914 Guru Group: Members Posts: 5,585 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Any idea what the cost will be for 1 5/8" heat exchangers? I am currently running stock 914-6 heat exchanges on a 3.2 motor. I know its choking the motor a bit, but it runs fine.
mb911 |
Dec 29 2015, 02:54 PM
Any idea what the cost will be for 1 5/8" heat exchangers? I am currently running stock 914-6 heat exchanges on a 3.2 motor. I know its choking the motor a bit, but it runs fine. Just a quick costing exercise would be per header 1 burns style merge collector $175, each flange $10, each bend is about $20 along with the heat exchanger which will not look stock but more similar to b&b.. Probably in 200 per heat exchanger in stainless steel and non polished.. I have also considered making heat exchangers for the headers that are already out there in the aftermarket.. I think my target would be 1500 for a set of complete headers/heat exchanger. |
Lo-Fi Version | Time is now: 17th May 2024 - 07:26 AM |
