Making Your Flasher Relay LED Compatible |
Spoke |
Dec 31 2015, 08:43 AM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
This thread is meant to help those implementing LED turnsignals on their 914.
Standard flasher relays were designed to flash 2 standard bulbs (21W each) for turnsignals or 4 standard bulbs with 4-ways on. LED replacements burn between 2W and 5W and electrically may not behave at all like a standard bulb. The LED replacements can cause all kinds of weird things like hyperflash (2x normal flash rate), dash indicators do not work, or the the flasher relay does nothing at all. The 914 flasher is different for early cars 70-73 than later 74+ mainly because of the tach indicators. Early cars have individual L and R indicators and the 74+ have a single L+R indicator. Both are handled differently by the flasher. There are LED-compatible flashers generally available at your FLAPS which are plug-in but not totally function compatible with the 914 standard flasher. The functional issue revolves around the 4th terminal which the 914 uses to activate the dash indicators. The aftermarket flasher relays are EP26 (4 terminal) and EP36 (3 terminal). I've seen these at Pep Boys, Autozone, and Advance Auto to name a few FLAPS, usually for less than $15. I'll detail the differences between early and late cars, as well as EP26 and EP36 in the next few posts. |
Geezer914 |
Mar 22 2023, 07:28 AM
Geezer914 Group: Members Posts: 1,409 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Converted the EP26 flasher. Turn signals work fine. Why does the turn signal indicator flash when the emergency brake is applied? This is on my 75 914.
rfinegan |
Dec 15 2023, 02:02 PM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
Watching...my 75 is now flashing with the parking brake too, did not have this issue in the past prior to the swap...any ideas?
Converted the EP26 flasher. Turn signals work fine. Why does the turn signal indicator flash when the emergency brake is applied? This is on my 75 914. |
Lo-Fi Version | Time is now: 14th May 2024 - 10:45 PM |
