| Series9 |
Jan 2 2016, 08:13 PM
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,453 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
So, I was given a lathe that had electrical problems.
I sorted those problems, and I am now looking for some simple projects so I can learn the machine. My first thought is to turn some clutch pulleys out of brass. Do you have other suggestions? Attached thumbnail(s) |
Series9 I was given a Metal Lathe. Jan 2 2016, 08:13 PM
r_towle Bronze suspension bushings.
Make a mount for a 91... Jan 2 2016, 08:17 PM
Series9
Make a mount for a 9... Jan 2 2016, 08:26 PM
r_towle Practice projects to get a feel for it.
Learn how ... Jan 2 2016, 08:29 PM
Series9
Learn how... Jan 2 2016, 08:42 PM
r_towle Look for tephlon impregnated bronze, not brass.
Gr... Jan 2 2016, 08:44 PM
jmill That's a pretty big lathe for making fairly sm... Jan 2 2016, 09:00 PM
pete000 Nice unit, we have the same one in our shop at wor... Jan 2 2016, 10:14 PM
toolguy Find an old retired machinist to teach you how to ... Jan 2 2016, 10:42 PM
porschetub
Find an old retired machinist to teach you how to... Jan 3 2016, 12:26 AM
Montreal914 I practice on the lathe at work and did some door ... Jan 3 2016, 01:15 AM
veekry9
Find an old retired machinist to teach you how to... Jan 3 2016, 03:41 AM
Mark Henry I agree with all of the above, start small project... Jan 3 2016, 05:46 AM
thieuster I agree with all of the above: especially those ab... Jan 3 2016, 06:31 AM
barefoot Get some Delrin or brass and make some of the rear... Jan 3 2016, 07:15 AM
bulitt And watch those carbide bits. When they shatter t... Jan 3 2016, 08:21 AM
ThePaintedMan Hey Joe! How bout a present or Christmas ornam... Jan 3 2016, 09:07 AM
cary Nice .............. Beautiful Machine
I bought a 1... Jan 3 2016, 11:04 AM
timothy_nd28 Chrome bezel gauge rings would be cool. Jan 3 2016, 11:55 AM
Series9 Wow!
Thanks for all the responses.
I'll ... Jan 3 2016, 03:09 PM
r_towle Make something square.... Jan 3 2016, 03:14 PM
veekry9
A test trinket,tolerances of +/-.003" ,in v... Jan 3 2016, 04:37 PM
Mueller Turners Cube made on a lathe.
http://www.cnccoo... Jan 3 2016, 04:54 PM
Series9
http://www.cncco... Jan 3 2016, 09:09 PM
Mueller
[quote name='Mueller' post='2285034' date='Jan 3 ... Jan 4 2016, 08:23 AM
ConeDodger
[quote name='Mueller' post='2285034' date='Jan 3... Jan 4 2016, 10:51 AM
Series9 Let's start with the basics.
What's the t... Jan 4 2016, 08:36 AM
Racer Chris
What's the ... Jan 4 2016, 09:21 AM
Mueller
What's the ... Jan 4 2016, 09:44 AM
mbseto Get a copy of Machinery's Handbook. It's ... Jan 4 2016, 08:46 AM
Series9 Thanks, Chris and Mike. Jan 4 2016, 09:53 AM
toolguy You can make anything you put your mind to. . .
M... Jan 4 2016, 11:04 AM
914bub
... Jan 4 2016, 11:39 AM
Kansas 914
You can make anything you put your mind to. . . ... Jan 4 2016, 12:11 PM
aircooledtechguy
... Jan 5 2016, 02:23 PM
NeunEinVier My first thought is to turn some clutch pulleys ou... Jan 4 2016, 12:00 PM
veekry9
You are in the fla machine belt,supporting nasa ... Jan 4 2016, 01:19 PM
Series9
The machine you have for cheap must be supported... Jan 4 2016, 02:14 PM
Mueller
The machine you have for cheap must be supporte... Jan 4 2016, 02:23 PM
Series9
Don't be tempted to put a chuck into a chuc... Jan 5 2016, 08:12 AM
zambezi
Don't be tempted to put a chuck into a chu... Jan 6 2016, 01:02 AM
Series9 I think I'll be getting this set: Jan 4 2016, 02:10 PM
veekry9 http://littlemachineshop.com/products/prod...20Too... Jan 4 2016, 03:40 PM
iwanta914-6 I used to operate Lathes and Mills when I was a ki... Jan 4 2016, 03:58 PM
veekry9 https://www.google.ca/search?q=miniature+v8...yA95... Jan 4 2016, 03:58 PM
toolguy
Look up KD... Jan 5 2016, 01:25 PM
veekry9
[quote name='Series9' post='2284654' date='Jan 2 ... Jan 5 2016, 02:38 PM
Olympic 1.7
Warning!
This is not a drill!
Graphic c... Jan 6 2016, 11:05 AM
VegasRacer
My first thought is to turn some clutch pulleys ... Jan 5 2016, 09:30 PM
Series9
My first thought is to turn some clutch pulleys... Jan 5 2016, 09:57 PM
MoveQik
My first thought is to turn some clutch pulleys... Jan 9 2016, 10:27 AM
toolguy 12X36 and 13x40 import {China or Taiwan] lathes al... Jan 6 2016, 10:25 AM
sean_v8_914 grab a chunk of broom stick. make a contoured hand... Jan 6 2016, 11:39 AM
veekry9
The horror technique was used on us in our teen... Jan 6 2016, 11:41 AM
Mueller
The horror technique was used on us in our tee... Jan 6 2016, 12:14 PM
76-914
So, I was given a lathe that had electrical probl... Jan 6 2016, 12:33 PM
mbseto Machine shop guys always have impressive stories. ... Jan 7 2016, 03:09 PM
Series9 So, I had to replace the front wheel bearings on t... Jan 7 2016, 05:11 PM
Mueller
So, I had to replace the front wheel bearings on ... Jan 7 2016, 05:33 PM
r_towle Btw,
I was joking about making something square.
... Jan 7 2016, 09:17 PM
veekry9
Now you too can make your own stroker crankshaf... Jan 8 2016, 01:55 AM
Series9 I'll be turning that rotor again...... :lol: Jan 8 2016, 08:35 AM
MoveQik
My first thought is to turn some clutch pulleys o... Jan 9 2016, 10:26 AM
914Bryan Lighten a flywheel Jan 10 2016, 07:14 PM
Series9
Lighten a flywheel
Okay, soon.
Right now I... Jan 11 2016, 07:28 PM
r_towle Lol, bet it was fun though. Jan 11 2016, 08:49 PM
toolguy Turning a brake rotor on an engine lathe is diffic... Jan 12 2016, 11:07 AM
Series9
Turning a brake rotor on an engine lathe is diffi... Jan 12 2016, 08:21 PM
Buckeye914 I kinda just skimmed through this post but with th... Jan 12 2016, 03:52 PM
veekry9 Several factors in the machining of shafts.
1)The ... Jan 12 2016, 08:04 PM
r_towle You might want to consider building a jig or facep... Jan 13 2016, 07:50 AM
worn I wouldn't worry too much - the projects have ... Jan 13 2016, 01:49 PM
veekry9 Useful attachment to mill splines on axleshafts.
A... Jan 14 2016, 08:10 AM
Series9
... Jan 14 2016, 08:54 AM
mbseto This is NOT a beginner project and I'm not rec... Jan 14 2016, 04:09 PM
Mueller
This is NOT a beginner project and I'm not re... Jan 14 2016, 04:39 PM
Series9
when you get bored with it......
:lol: No ... Jan 14 2016, 05:55 PM
veekry9 https://forum.linuxcnc.org/forum/index/
Proprietar... Jan 14 2016, 05:33 PM
Mueller
Proprieta... Jan 14 2016, 05:51 PM
r_towle You should make a clock out of the rotor and hang ... Jan 14 2016, 07:18 PM
Series9
You should make a clock out of the rotor and hang... Jan 15 2016, 08:20 AM
Series9 I have my first revenue project.
I'll be modi... Jan 24 2016, 06:20 PM
r_towle Oh no.... Jan 24 2016, 06:21 PM
veekry9 Broaching or shaping,rolling or milling?
https://... Jan 24 2016, 06:27 PM
mskala Or you could trade your lathe for 250 beanie babie... Jan 28 2016, 07:23 PM
Series9 Observations from the mind of a beginner on the la... Jan 28 2016, 07:53 PM
r_towle Nice clock Jan 28 2016, 08:20 PM
Series9 I don't want to pay the price, but it looks li... Jan 29 2016, 08:06 AM
toolguy Look at KDK style first. . much better and a lot ... Jan 29 2016, 09:39 AM
jd74914
Those are so cool with... Jan 29 2016, 10:03 AM
Series9
Look at KDK style first. . much better and a lot... Jan 29 2016, 10:28 AM
Racer Chris I use Aloris BX series. They have sales on a regul... Jan 29 2016, 10:53 AM
toolguy Where is the height adjustment on those?
There ar... Jan 29 2016, 11:32 AM
nathansnathan I like to use what's called a "dial test ... Jan 29 2016, 05:57 PM
r_towle How can you inform your neighbors that it's no... Feb 8 2016, 05:18 PM
veekry9 https://www.google.ca/search?q=lathe+tool+h...Ib7E... Feb 8 2016, 06:46 PM
mbseto
I ruined a parting tool, so I need more informati... Feb 9 2016, 10:45 AM
veekry9
Making your own bushings is a handy skill.
Tur... Feb 9 2016, 10:38 PM
r_towle Seriously Feb 9 2016, 11:08 PM
veekry9
Thread rolling for fun.
[url=https://www.google... Feb 10 2016, 12:02 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:34 AM |
