> I was given a Metal Lathe., Help me choose projects.
Series9
post Jan 2 2016, 08:13 PM
Post #41
Lesbians taste like chicken.
So, I was given a lathe that had electrical problems.
I sorted those problems, and I am now looking for some simple projects so I can learn the machine.
My first thought is to turn some clutch pulleys out of brass. Do you have other suggestions?
Series9   I was given a Metal Lathe.   Jan 2 2016, 08:13 PM
r_towle   Bronze suspension bushings. Make a mount for a 91...   Jan 2 2016, 08:17 PM
Series9   Bronze suspension bushings. Make a mount for a 9...   Jan 2 2016, 08:26 PM
r_towle   Practice projects to get a feel for it. Learn how ...   Jan 2 2016, 08:29 PM
Series9   Practice projects to get a feel for it. Learn how...   Jan 2 2016, 08:42 PM
r_towle   Look for tephlon impregnated bronze, not brass. Gr...   Jan 2 2016, 08:44 PM
jmill   That's a pretty big lathe for making fairly sm...   Jan 2 2016, 09:00 PM
pete000   Nice unit, we have the same one in our shop at wor...   Jan 2 2016, 10:14 PM
toolguy   Find an old retired machinist to teach you how to ...   Jan 2 2016, 10:42 PM
porschetub   Find an old retired machinist to teach you how to...   Jan 3 2016, 12:26 AM
Montreal914   I practice on the lathe at work and did some door ...   Jan 3 2016, 01:15 AM
veekry9   Find an old retired machinist to teach you how to...   Jan 3 2016, 03:41 AM
Mark Henry   I agree with all of the above, start small project...   Jan 3 2016, 05:46 AM
thieuster   I agree with all of the above: especially those ab...   Jan 3 2016, 06:31 AM
barefoot   Get some Delrin or brass and make some of the rear...   Jan 3 2016, 07:15 AM
bulitt   And watch those carbide bits. When they shatter t...   Jan 3 2016, 08:21 AM
ThePaintedMan   Hey Joe! How bout a present or Christmas ornam...   Jan 3 2016, 09:07 AM
cary   Nice .............. Beautiful Machine I bought a 1...   Jan 3 2016, 11:04 AM
timothy_nd28   Chrome bezel gauge rings would be cool.   Jan 3 2016, 11:55 AM
Series9   Wow! Thanks for all the responses. I'll ...   Jan 3 2016, 03:09 PM
r_towle   Make something square....   Jan 3 2016, 03:14 PM
veekry9   A test trinket,tolerances of +/-.003" ,in v...   Jan 3 2016, 04:37 PM
Mueller   Turners Cube made on a lathe. http://www.cnccoo...   Jan 3 2016, 04:54 PM
Series9   Turners Cube made on a lathe. http://www.cncco...   Jan 3 2016, 09:09 PM
Mueller   [quote name='Mueller' post='2285034' date='Jan 3 ...   Jan 4 2016, 08:23 AM
ConeDodger   [quote name='Mueller' post='2285034' date='Jan 3...   Jan 4 2016, 10:51 AM
Series9   Let's start with the basics. What's the t...   Jan 4 2016, 08:36 AM
Racer Chris   Let's start with the basics. What's the ...   Jan 4 2016, 09:21 AM
Mueller   Let's start with the basics. What's the ...   Jan 4 2016, 09:44 AM
mbseto   Get a copy of Machinery's Handbook. It's ...   Jan 4 2016, 08:46 AM
Series9   Thanks, Chris and Mike.   Jan 4 2016, 09:53 AM
toolguy   You can make anything you put your mind to. . . M...   Jan 4 2016, 11:04 AM
914bub   You can make anything you put your mind to. . . ...   Jan 4 2016, 11:39 AM
Kansas 914   You can make anything you put your mind to. . . ...   Jan 4 2016, 12:11 PM
aircooledtechguy   You can make anything you put your mind to. . . ...   Jan 5 2016, 02:23 PM
NeunEinVier   My first thought is to turn some clutch pulleys ou...   Jan 4 2016, 12:00 PM
veekry9   You are in the fla machine belt,supporting nasa ...   Jan 4 2016, 01:19 PM
Series9   The machine you have for cheap must be supported...   Jan 4 2016, 02:14 PM
Mueller   The machine you have for cheap must be supporte...   Jan 4 2016, 02:23 PM
Series9   Don't be tempted to put a chuck into a chuc...   Jan 5 2016, 08:12 AM
zambezi   Don't be tempted to put a chuck into a chu...   Jan 6 2016, 01:02 AM
Series9   I think I'll be getting this set:   Jan 4 2016, 02:10 PM
veekry9   http://littlemachineshop.com/products/prod...20Too...   Jan 4 2016, 03:40 PM
iwanta914-6   I used to operate Lathes and Mills when I was a ki...   Jan 4 2016, 03:58 PM
veekry9   https://www.google.ca/search?q=miniature+v8...yA95...   Jan 4 2016, 03:58 PM
toolguy   I think I'll be getting this set: Look up KD...   Jan 5 2016, 01:25 PM
veekry9   [quote name='Series9' post='2284654' date='Jan 2 ...   Jan 5 2016, 02:38 PM
Olympic 1.7   Warning! This is not a drill! Graphic c...   Jan 6 2016, 11:05 AM
VegasRacer   My first thought is to turn some clutch pulleys ...   Jan 5 2016, 09:30 PM
Series9   My first thought is to turn some clutch pulleys...   Jan 5 2016, 09:57 PM
MoveQik   My first thought is to turn some clutch pulleys...   Jan 9 2016, 10:27 AM
toolguy   12X36 and 13x40 import {China or Taiwan] lathes al...   Jan 6 2016, 10:25 AM
sean_v8_914   grab a chunk of broom stick. make a contoured hand...   Jan 6 2016, 11:39 AM
veekry9   The horror technique was used on us in our teen...   Jan 6 2016, 11:41 AM
Mueller   The horror technique was used on us in our tee...   Jan 6 2016, 12:14 PM
76-914   So, I was given a lathe that had electrical probl...   Jan 6 2016, 12:33 PM
mbseto   Machine shop guys always have impressive stories. ...   Jan 7 2016, 03:09 PM
Series9   So, I had to replace the front wheel bearings on t...   Jan 7 2016, 05:11 PM
Mueller   So, I had to replace the front wheel bearings on ...   Jan 7 2016, 05:33 PM
r_towle   Btw, I was joking about making something square. ...   Jan 7 2016, 09:17 PM
veekry9   Now you too can make your own stroker crankshaf...   Jan 8 2016, 01:55 AM
Series9   I'll be turning that rotor again...... :lol:   Jan 8 2016, 08:35 AM
MoveQik   My first thought is to turn some clutch pulleys o...   Jan 9 2016, 10:26 AM
914Bryan   Lighten a flywheel   Jan 10 2016, 07:14 PM
Series9   Lighten a flywheel Okay, soon. Right now I...   Jan 11 2016, 07:28 PM
r_towle   Lol, bet it was fun though.   Jan 11 2016, 08:49 PM
toolguy   Turning a brake rotor on an engine lathe is diffic...   Jan 12 2016, 11:07 AM
Series9   Turning a brake rotor on an engine lathe is diffi...   Jan 12 2016, 08:21 PM
Buckeye914   I kinda just skimmed through this post but with th...   Jan 12 2016, 03:52 PM
veekry9   Several factors in the machining of shafts. 1)The ...   Jan 12 2016, 08:04 PM
r_towle   You might want to consider building a jig or facep...   Jan 13 2016, 07:50 AM
worn   I wouldn't worry too much - the projects have ...   Jan 13 2016, 01:49 PM
veekry9   Useful attachment to mill splines on axleshafts. A...   Jan 14 2016, 08:10 AM
Series9   Useful attachment to mill splines on axleshafts. ...   Jan 14 2016, 08:54 AM
mbseto   This is NOT a beginner project and I'm not rec...   Jan 14 2016, 04:09 PM
Mueller   This is NOT a beginner project and I'm not re...   Jan 14 2016, 04:39 PM
Series9   when you get bored with it...... :lol: No ...   Jan 14 2016, 05:55 PM
veekry9   https://forum.linuxcnc.org/forum/index/ Proprietar...   Jan 14 2016, 05:33 PM
Mueller   https://forum.linuxcnc.org/forum/index/ Proprieta...   Jan 14 2016, 05:51 PM
r_towle   You should make a clock out of the rotor and hang ...   Jan 14 2016, 07:18 PM
Series9   You should make a clock out of the rotor and hang...   Jan 15 2016, 08:20 AM
Series9   I have my first revenue project. I'll be modi...   Jan 24 2016, 06:20 PM
r_towle   Oh no....   Jan 24 2016, 06:21 PM
veekry9   Broaching or shaping,rolling or milling? https://...   Jan 24 2016, 06:27 PM
mskala   Or you could trade your lathe for 250 beanie babie...   Jan 28 2016, 07:23 PM
Series9   Observations from the mind of a beginner on the la...   Jan 28 2016, 07:53 PM
r_towle   Nice clock   Jan 28 2016, 08:20 PM
Series9   I don't want to pay the price, but it looks li...   Jan 29 2016, 08:06 AM
toolguy   Look at KDK style first. . much better and a lot ...   Jan 29 2016, 09:39 AM
jd74914   Look at KDK style first. Those are so cool with...   Jan 29 2016, 10:03 AM
Series9   Look at KDK style first. . much better and a lot...   Jan 29 2016, 10:28 AM
Racer Chris   I use Aloris BX series. They have sales on a regul...   Jan 29 2016, 10:53 AM
toolguy   Where is the height adjustment on those? There ar...   Jan 29 2016, 11:32 AM
nathansnathan   I like to use what's called a "dial test ...   Jan 29 2016, 05:57 PM
r_towle   How can you inform your neighbors that it's no...   Feb 8 2016, 05:18 PM
veekry9   https://www.google.ca/search?q=lathe+tool+h...Ib7E...   Feb 8 2016, 06:46 PM
mbseto   I ruined a parting tool, so I need more informati...   Feb 9 2016, 10:45 AM
veekry9   Making your own bushings is a handy skill. Tur...   Feb 9 2016, 10:38 PM
r_towle   Seriously   Feb 9 2016, 11:08 PM
veekry9   Thread rolling for fun. [url=https://www.google...   Feb 10 2016, 12:02 AM
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 2nd April 2026 - 07:51 AM
