Subydoo A 914 Watercooled, If it aint broke u aint tryin! I try too hard.... |
tazz9924 |
Jan 17 2016, 01:40 AM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
Hello ive thought about doing this for a while but lately ive had an itch and lots of questions and little want to open 1000s of threads so here it is. Subydoo i bought a 1970 914 from a one legged guy in my home town who bought it from a crip in a neighboring city. straight off the bat i knew i was gonna ej turbo swap it.
jimkelly |
Apr 3 2016, 11:56 AM
I too bought the radiator with fans but no shroud in error. you'll probably need s shroud. I reused my renegade shroud but I am finding this radiator struggles to keep a sbc v8 at 190 degrees. as the summer temps start to rise, I expect problems (IMG:style_emoticons/default/sad.gif) I may put a fan on each wheel well opening to expedite hot air flow out of front trunk.
tazz9924 |
Apr 6 2016, 01:05 PM
I too bought the radiator with fans but no shroud in error. you'll probably need s shroud. I reused my renegade shroud but I am finding this radiator struggles to keep a sbc v8 at 190 degrees. as the summer temps start to rise, I expect problems (IMG:style_emoticons/default/sad.gif) I may put a fan on each wheel well opening to expedite hot air flow out of front trunk. Are you saying you bought this radiator? im making a shroud right now and its not turning out too bad had a little change of plans at one point but it should work. i also have fairly big openings for exhaust air. |
Lo-Fi Version | Time is now: 12th May 2024 - 10:14 PM |
