Removing LATE model front bumper. |
patssle |
Jan 17 2016, 03:46 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Okay what's the tip for removing the LATE model front bumpers? The big black heavy piece with the 2 tits. It's been a little frustrating and all the comments I've found are for the early model.
Bruce Hinds |
Jan 17 2016, 03:55 PM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
Remove 2 big bolts (19mm) from the underside. Then when it's loose, with your fingers just pry the rubber sides loose, they're just held behind a tab. Then just pull the whole thing forward.
colingreene |
Jan 17 2016, 04:51 PM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
be ready to catch, they are not light
patssle |
Jan 17 2016, 05:15 PM
Ahhh just 2 bolts. So easy once you know! Thanks guys.
9fourteen14 |
Jan 17 2016, 09:01 PM
PORSCHE LUVA Group: Members Posts: 135 Joined: 5-July 15 From: boston Member No.: 18,920 Region Association: North East States |
Okay what's the tip for removing the LATE model front bumpers? The big black heavy piece with the 2 tits. It's been a little frustrating and all the comments I've found are for the early model. I asked the same question. They posted a picture for me. It is easier than it looks. Get the gits soft oil or hot water or just pull they will come out. I took the 74 2.0 bumpers and bumper tops off to clean and fix They are beautiful now. And fixed. 914 luva |
9fourteen14 |
Jan 18 2016, 07:37 AM
Okay what's the tip for removing the LATE model front bumpers? The big black heavy piece with the 2 tits. It's been a little frustrating and all the comments I've found are for the early model. Be care not to break the bolts.?..VERY EXPENSIVE TO REPLACE. I did but figured a perfect way to replace them. Dig the old one out and pack some epoxy in the with a new bolt and plastic Rubber washer. Don't break the bolts on bumper or toppers! |
Lo-Fi Version | Time is now: 17th May 2024 - 05:31 PM |
