Oil Galley Plugs, Just replace the five big ones? |
saigon71 |
Jan 18 2016, 01:49 PM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
In preparation for an engine rebuild, I wanted to get myself up to speed on drilling/tapping the oil galley plugs.
Search revealed conflicting information about whether all should be removed and tapped or just the five big ones. What's the current school of thought on this? Also, what size plugs and drill/tap will I need. Thanks! http://www.914world.com/bbs2/index.php?sho...=103988&hl= |
Porschef |
Jan 18 2016, 05:52 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Bob, I did mine as a precaution before installing the new engine. Just the five as shown in your link. Not a difficult job, but you need to be careful, I recall lots of grease on the drill bit and also a tape plug that I made up when tapping the holes.
I rented the tap from Chris Foley, and got the plugs from McMasterCarr. I don't recall the drill bit size, but I have it out in the garage. I'll hobble out tomorrow and check it out. Overall, it just gave me peace of mind. One of the plugs began to spin when I drilled the initial hole to pull it out, the others were probably fine. Glad I'd done it tho. |
Mark Henry |
Jan 19 2016, 08:15 AM
3/8" NPT pipe tap, 9/16 drill bit use steel plugs.
Go slow, for a bare case I use WD-40 for lube. Keep the tap square, remove and clean the tap often when cutting. When you tap check to make sure the plug goes in deep enough, but not too deep, you want it just a bit proud. Clean well, I pressure wash the case. Then use loctite to set the plugs, Never use teflon tape on a NPT plug or fitting, especially in aluminum. Some will say you should use brass or aluminum plugs because they have the same expansion rates. IMHO in this case it's horse shit, I've never once seen a steel plug leak, but I have seen brass or aluminum plugs strip the hex out. |
r_towle |
Jan 19 2016, 08:29 AM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
3/8" NPT pipe tap, 9/16 drill bit use steel plugs. Go slow, for a bare case I use WD-40 for lube. Keep the tap square, remove and clean the tap often when cutting. When you tap check to make sure the plug goes in deep enough, but not too deep, you want it just a bit proud. Clean well, I pressure wash the case. Then use loctite to set the plugs, Never use teflon tape on a NPT plug or fitting, especially in aluminum. Some will say you should use brass or aluminum plugs because they have the same expansion rates. IMHO in this case it's horse shit, I've never once seen a steel plug leak, but I have seen brass or aluminum plugs strip the hex out. Where did you order the allen head plugs? |
Mark Henry |
Jan 19 2016, 09:02 AM
Where did you order the allen head plugs? Pretty common plug, any plumbing supply definetly should have them on the shelf. Most Hydraulic and hardware supply stores should have them as well. Here I can get them at Home Debit and Low's. I bought a bunch of 1/8"NPT plugs for my /6 engine cam towers at Fastenal. Personally I have a hardware guy who comes by with a panel truck every 4-6 weeks, I bought them right off the truck. Mine are Paulin/papco brand. |
Dave_Darling |
Jan 19 2016, 10:33 AM
IIRC, there is one plug that will block an important passage if you run it in too deep. (Might apply only to some cases?) You obviously don't want to do that.
You can replace the small plugs as well if you want. It certainly makes cleaning the passages out thoroughly easier if you do. --DD |
McMark |
Jan 19 2016, 10:36 AM
McMaster has them.
Mark Henry |
Jan 19 2016, 11:33 AM
IIRC, there is one plug that will block an important passage if you run it in too deep. (Might apply only to some cases?) You obviously don't want to do that. You can replace the small plugs as well if you want. It certainly makes cleaning the passages out thoroughly easier if you do. --DD IIRC that is the 3/4 side lifter oil galley. You can leave that one quite proud if you like, but the other two will interfere with the flywheel if they are too proud. Make damn sure of your plug depths before you begin your build. |
rhcb914 |
Jan 19 2016, 08:06 PM
member Group: Members Posts: 358 Joined: 3-February 04 From: Boston, MA Member No.: 1,626 |
I bought a box of 100 steel hex hed plugs from Grainger. It was like $20.
Harbor Freight has a $12 tap kit which I bought 2 of. Grind down the lead of 1 tap. Use the full tap to start the threads then chase with the ground down tap. Cut a little check the depth of the plug. Repeat until the plugs are just slightly proud of the case. Make sure you clean the galleys really well! |
Jake Raby |
Jan 19 2016, 09:57 PM
I'm building a 2270 for a World member now.. Last week I removed his 5 plugs. Of the 5 3 of them were in tight, one came out while drilling a hole in the center to extract it, and another basically fell out in the ultrasonic cleaner just from a bit of case expansion and sound waves.
Behind those were some really nasty crap, some of it was 3/8" deep and packed in the tight turns right behind the galley. Pulling these plugs, and threading the case to accept the 3/8 NPT plugs is simply a must. |
saigon71 |
Feb 2 2016, 08:29 PM
Thanks for the responses and recommendations. (IMG:style_emoticons/default/beerchug.gif)
Picked up everything I needed today for the five main galley plugs: I figured out afterward that there is a kit available for slightly less money than I have invested in this task. (IMG:style_emoticons/default/dry.gif) Here it is in case anyone else is looking: http://www.germansupply.com/home/customer/...productid=16842 |
914werke |
Feb 2 2016, 10:10 PM
"I got blisters on me fingers" Group: Members Posts: 10,062 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
are those steel or Alum. plugs? |
saigon71 |
Feb 3 2016, 08:10 AM
Olympic 914 |
Feb 3 2016, 08:30 AM
Group: Members Posts: 1,668 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
When I did mine I got an extra tap and ground the bottom of it to use as a bottoming tap. I started the threads with the regular tap, then ran the bottoming tap in.
That way I was able to thread the plugs in without having to drill deeper. |
McMark |
Feb 3 2016, 08:35 AM
(IMG:style_emoticons/default/agree.gif) A second tap is handy.
Also, when drilling the aluminum DON'T PUSH the drill. Pressure will make the bit grab and will spin the drill. Best is to use a drill that has a clutch on it, for safety. If your drill doesn't have a clutch, be ready to completely let go of it if the bit catches. But if you keep very very very very very light pressure on the bit, you will minimize the bit-catches. |
Mark Henry |
Feb 3 2016, 10:20 AM
(IMG:style_emoticons/default/agree.gif) A second tap is handy. Also, when drilling the aluminum DON'T PUSH the drill. Pressure will make the bit grab and will spin the drill. Best is to use a drill that has a clutch on it, for safety. If your drill doesn't have a clutch, be ready to completely let go of it if the bit catches. But if you keep very very very very very light pressure on the bit, you will minimize the bit-catches. Keep spraying it with WD-40 and it doesn't catch as much and no build-up on the tool. Is there better lube? Likely, but everyone has a can of WD-40 kicking around. |
McMark |
Feb 3 2016, 12:58 PM
Oh yeah. That for sure! (IMG:style_emoticons/default/agree.gif)
nathansnathan |
Feb 3 2016, 05:14 PM
Senior Member Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
When I did this the 1st time, I had got some 3/8" NPT plugs from mcmaster-carr and they were way thicker (would have to be run deeper) than the ones I ended up using which I got from rimco. I don't think they would have worked for the outer one by the oil cooler.
I was able to use 1 tap and just ground it down alternately to running it, like it became a bottoming tap by the time I was done. You just need it for that one by the oil cooler. wd-40 is relatively bad as a lubricant. I think it's pretty bad for everything actually and refuse to buy such a crappy consumer-ish product. (IMG:style_emoticons/default/tongue.gif) For such an important job I would use actual oil and go for class A threads. I used loctite 518 to seal them, as it sets anaerobically. |
Mark Henry |
Feb 3 2016, 08:38 PM
When I did this the 1st time, I had got some 3/8" NPT plugs from mcmaster-carr and they were way thicker (would have to be run deeper) than the ones I ended up using which I got from rimco. I don't think they would have worked for the outer one by the oil cooler. I was able to use 1 tap and just ground it down alternately to running it, like it became a bottoming tap by the time I was done. You just need it for that one by the oil cooler. wd-40 is relatively bad as a lubricant. I think it's pretty bad for everything actually and refuse to buy such a crappy consumer-ish product. (IMG:style_emoticons/default/tongue.gif) For such an important job I would use actual oil and go for class A threads. I used loctite 518 to seal them, as it sets anaerobically. (IMG:style_emoticons/default/rolleyes.gif) Meh.... guess I've been doing it wrong since the early 90's, oh well just a few hundred or more type one full flow and T4 cases. The plugs by the cooler can sit proud, they won't interfere with anything. BTW if you are going with a full flow system you only really have to do the one top hole. |
McMark |
Feb 3 2016, 09:50 PM
Wd-40 is better than goo-gone for removing stick residue. (IMG:style_emoticons/default/tongue.gif)
Lo-Fi Version | Time is now: 17th May 2024 - 11:32 AM |
