Wide body wheel widths and offset |
FastFroggy |
Jan 18 2016, 07:37 PM
Newbie Group: Members Posts: 47 Joined: 27-November 15 From: Ann Arbor MI Member No.: 19,415 Region Association: Upper MidWest |
I was taking a break from the fiberglass repair and noticed on my car that the tires sit different front to rear. then I was surprised that the fronts are 9in and rears are 8in wide rims... then the final surprise was that the offsets were significantly different.
My car is a 5 bolt conversion 73 914-4 of unknown origin with wide body fenders. Please explain the general convention on this. Thanks |
ge9146 |
Mar 4 2017, 10:45 AM
Newbie Group: Members Posts: 47 Joined: 5-March 05 From: Western Michigan Member No.: 3,716 Region Association: Upper MidWest |
I just ran across a great saying for race car construction.
"Start with the tires you will use and build the car around them" If your rules will allow it, BFG just released a new tire that could be very useful. They now have a Rival S 1.5 that is sized 245/40x 15 that could work well on your 8x15 wheels. That is a 200 tread wear tire if you have to meet some class restriction. If you do not have any tread wear class restriction and you want something perhaps a bit stickier, the old standby TOYO RA-1 is a great long lasting track tire too. Tire Rack has it in a 225/45x15 or a 225/50x15. Of course Hoosiers are faster too but the are expensive and do not last very long. You get what you pay for. |
wndsrfr |
Mar 4 2017, 06:57 PM
Senior Member Group: Members Posts: 1,429 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
I've been on Toyo's for years--shaved RA1's and now RR's in 225/45/15 using 8 inch rims. They will fit on the 7 inch rims fine. If you stay with 225's on all 4 corners (square setup) then you can move the tires around, flip them, etc. With your 1.7 I don't think you need 245's for the rear. If you're going to street drive the car as well as track it, then get the RA1's and leave 8/32'nds of tread after shaving.
Lo-Fi Version | Time is now: 15th May 2024 - 06:21 AM |
