European front turn signal functions |
Puebloswatcop |
Jan 19 2016, 10:10 PM
Senior Member Group: Members Posts: 1,388 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
Okay everyone,
I am in the process of switching over to the European style front turn signal lights. Can anyone tell me what the functions are of each light. Does the bottom light stay on constant? Does the yellow portion function as a parking light and turn signal still? Just trying to get this right. (IMG:style_emoticons/default/smash.gif) Thanks for any help, |
toolguy |
Jan 19 2016, 10:38 PM
The lower white portion is the parking lights. . Yellow is turn.
In a real Euro light bucket, the top [turn] connector is a single filament socket, The spade wire connectors have a different physical arrangement than a USA bucket. Euro bucket is on the top in the picture, notice the single spade with the insulated base. . this is the lower [white] light lead Attached image(s) |
falcor75 |
Jan 19 2016, 11:31 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
And yes the white light is on the whole time and only the amber one blinks on turn signal.
SKL1 |
Jan 20 2016, 12:48 AM
Senior Member Group: Members Posts: 1,597 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Easy way to get that function with the euro lenses is to get Spoke's LED bulbs. He makes one that works great, plug and play. Have them on my '73.
Never have figured out though why people put on the euro lenses, but leave those hideous side bulbs... |
Puebloswatcop |
Jan 20 2016, 05:26 AM
Easy way to get that function with the euro lenses is to get Spoke's LED bulbs. He makes one that works great, plug and play. Have them on my '73. Never have figured out though why people put on the euro lenses, but leave those hideous side bulbs... I agree, my hideous (IMG:style_emoticons/default/barf.gif) side lights a gone. |
Darren C |
Jan 20 2016, 05:54 AM
Member Group: Members Posts: 392 Joined: 26-December 14 From: Chichester UK Member No.: 18,255 Region Association: England |
Fabricated bulb holders
(IMG:http://www.914world.com/bbs2/uploads_offsite/i265.photobucket.com-18255-1453290894.1.jpg) Fitted into housings (IMG:http://www.914world.com/bbs2/uploads_offsite/i265.photobucket.com-18255-1453290894.2.jpg) Cables fed through existing holes inside insulated part of housing (IMG:http://www.914world.com/bbs2/uploads_offsite/i265.photobucket.com-18255-1453290895.3.jpg) Change amber lens to split clear/amber Feed power to new bulb from removed marker lamp cable. I only ran extra earth for peace of mind. US lamp housings have pins cast to hold the extra power cable. I heat shrunk over old terminal thats made redundant to prevent confusion in what to reconnect. Use standard twin bulb in amber position but only one filament in use (otherwise its a bigger job to change bulb holder) You can check out in more detail in my Build off challenge thread as its updated ! |
jkb944t |
Jan 20 2016, 06:51 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
Fabricated bulb holders Fitted into housings Cables fed through existing holes inside insulated part of housing Change amber lens to split clear/amber Feed power to new bulb from removed marker lamp cable. I only ran extra earth for peace of mind. US lamp housings have pins cast to hold the extra power cable. I heat shrunk over old terminal thats made redundant to prevent confusion in what to reconnect. Use standard twin bulb in amber position but only one filament in use (otherwise its a bigger job to change bulb holder) You can check out in more detail in my Build off challenge thread as its updated ! This info is very helpful since I need to do this next on my car. Now if I can only figure out how to clean the crud off of the outside of the housings so they look nicer. Jeff B |
Darren C |
Jan 20 2016, 06:54 AM
This info is very helpful since I need to do this next on my car. Now if I can only figure out how to clean the crud off of the outside of the housings so they look nicer. Jeff B Mine were awful, covered in stone guard, tar, sand and dirt. White spirit and a brass bristle detail wire brush got them like you see in the pictures. |
Cairo94507 |
Jan 20 2016, 07:32 AM
Michael Group: Members Posts: 9,716 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Nice job Darren.
Puebloswatcop |
Jan 20 2016, 11:03 AM
Fabricated bulb holders Fitted into housings Cables fed through existing holes inside insulated part of housing Change amber lens to split clear/amber Feed power to new bulb from removed marker lamp cable. I only ran extra earth for peace of mind. US lamp housings have pins cast to hold the extra power cable. I heat shrunk over old terminal thats made redundant to prevent confusion in what to reconnect. Use standard twin bulb in amber position but only one filament in use (otherwise its a bigger job to change bulb holder) You can check out in more detail in my Build off challenge thread as its updated ! Those are really nice Darren. Well made. Thanks for sharing this, it is awesome and I really like the neat professional looking install. I am just kind of particular that way. Kevin |
Puebloswatcop |
Jan 20 2016, 11:08 AM
Okay everyone, I am in the process of switching over to the European style front turn signal lights. Can anyone tell me what the functions are of each light. Does the bottom light stay on constant? Does the yellow portion function as a parking light and turn signal still? Just trying to get this right. (IMG:style_emoticons/default/smash.gif) Thanks for any help, Thanks everyone. Now I know and I feel confident in getting it set up and hooked up correctly. |
porschetub |
Jan 20 2016, 12:19 PM
Okay everyone, I am in the process of switching over to the European style front turn signal lights. Can anyone tell me what the functions are of each light. Does the bottom light stay on constant? Does the yellow portion function as a parking light and turn signal still? Just trying to get this right. (IMG:style_emoticons/default/smash.gif) Thanks for any help, Thanks everyone. Now I know and I feel confident in getting it set up and hooked up correctly. Now that's done right,even nicer than the ones offered on ebay Germany,the two other suppliers in the US could learn a lessen on how to make them from you, great skills. Are you thinking of making these to sell? |
Jan 20 2016, 03:27 PM
Puebloswatcop |
Jan 20 2016, 04:54 PM
Never have figured out though why people put on the euro lenses, but leave those hideous side bulbs... Because not everyone can do welding, body work, and painting... --DD That is a good, plausible reason Dave. (IMG:style_emoticons/default/welder.gif) |
rhodyguy |
Aug 7 2020, 12:12 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,063 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Martin Baker made, or makes, slick euro style turn signal bucket conversions. Not with a plastic divider.
dt4 |
Aug 7 2020, 01:25 PM
Senior Member Group: Members Posts: 502 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England |
Martin Baker made, or makes, slick euro style turn signal bucket conversions. Not with a plastic divider. @rhodyguy is Martin a member on here |
dt4 |
Aug 7 2020, 01:31 PM
Martin Baker made, or makes, slick euro style turn signal bucket conversions. Not with a plastic divider. @rhodyguy is Martin a member on here scratch that, I found him cheers (IMG:style_emoticons/default/beerchug.gif) |
dt4 |
Aug 8 2020, 01:36 AM
Fabricated bulb holders (IMG:http://www.914world.com/bbs2/uploads_offsite/i265.photobucket.com-18255-1453290894.1.jpg) Fitted into housings (IMG:http://www.914world.com/bbs2/uploads_offsite/i265.photobucket.com-18255-1453290894.2.jpg) Cables fed through existing holes inside insulated part of housing (IMG:http://www.914world.com/bbs2/uploads_offsite/i265.photobucket.com-18255-1453290895.3.jpg) Change amber lens to split clear/amber Feed power to new bulb from removed marker lamp cable. I only ran extra earth for peace of mind. US lamp housings have pins cast to hold the extra power cable. I heat shrunk over old terminal thats made redundant to prevent confusion in what to reconnect. Use standard twin bulb in amber position but only one filament in use (otherwise its a bigger job to change bulb holder) You can check out in more detail in my Build off challenge thread as its updated ! what type of bulb / bulb holder is this using please? |
GeorgeKopf |
Aug 28 2021, 07:46 PM
Member Group: Members Posts: 172 Joined: 9-February 21 From: Princeton, NJ Member No.: 25,186 Region Association: MidAtlantic Region |
I think I found those 1156 bulb holders.
https://www.amazon.com/BA15s-Bayonet-Socket...3163&sr=8-3 or https://www.amazon.com/gp/product/B00R50E8W...DKNY9&psc=1 Looks like they have been bent up to parallel with the plate. Thanks. George |
wonkipop |
Aug 30 2021, 05:18 AM
Advanced Member Group: Members Posts: 4,247 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
its pretty funny all this stuff converting us spec lighting to euro spec.
i would love to run my 914 american spec in aus. its so pretty american spec night lighting. but i am not allowed to. but i managed to avoid the parker light bs in the front lenses by incorporating it into the pop up head lights. i have parkers in those. which let me run the full orange lenses as pure indicators here in aus. the grass is always greener on the other side? i even like warts! |
Lo-Fi Version | Time is now: 27th April 2024 - 04:14 PM |
