Aux Air Valve Hose |
MDTerp |
Jan 31 2016, 09:05 AM
Member Group: Members Posts: 101 Joined: 20-May 08 From: Maryland Member No.: 9,075 Region Association: MidAtlantic Region |
I bought a used Aux Air Valve because my cold idle was low and hunting. Went to replace the valve and found this kinked hose. Turned the hose around, rerouted it without the kink and problem solved. The hose seems short and hard to avoid it getting kinked. Did I use the wrong length hose here? Or something else?
Lo-Fi Version | Time is now: 17th May 2024 - 02:51 AM |
