MOMO Hub - Continued ..., got it to work! |
Jun 13 2003, 09:55 PM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
ok, first of all, i have to say, im suuuuuuuch a moron. more about that later ...
Mark V: thanks for sending the hub. i tried it today, it would work (sorta) but it leaves the infamous BIG GAP. everything bolts on fine, but there's a gap of several inches. plus, the wheel comes WAY too far out, like right on my nose (IMG:style_emoticons/default/sad.gif) soooo, can't use it, will send it back. thanks again (IMG:style_emoticons/default/pray.gif) and here's the solution: when i upgraded my steering column from '70 to '75 (?Mueller?) i had to take the whole assembly apart and switch the main shaft! and then of course forgot about it. (IMG:style_emoticons/default/fighting19.gif) so what i ended up with is a '75 steering column except for the shaft, which is still the '70. i had to do that so the rods would fit together without binding. my old MOMO still seemed to fit except it wouldn't slide down far enough to get the nut started on the thread. sooooo, i had a closer look today and it turns out the pastic cover at the end of the Hub hits the Windshield wiper lever. DOH, my '70 didn't have that lever and the therefore the cover was about 1cm too long. shaved it off and voila: the Hub & Wheel fit perfectly ... ahhhhh, i'm such a dumb-ass, sometimes ... (IMG:style_emoticons/default/wacko.gif) Andy |
seanery |
Jun 13 2003, 09:57 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,846 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
Be careful in your use of the word moron! I've all but copyrightten, copyrighted, well you know what I mean, that one!
Jun 13 2003, 10:04 PM
QUOTE(seanery @ Jun 13 2003, 08:57 PM) Be careful in your use of the word moron! I've all but copyrightten, copyrighted, well you know what I mean, that one! alright, you're the Moron and i'm the occasional Dumb-Ass (DA). ok? Andy |
MarkV |
Jun 13 2003, 10:55 PM
QUOTE(SirAndy @ Jun 13 2003, 07:55 PM) sooooo, i had a closer look today and it turns out the pastic cover at the end of the Hub hits the Windshield wiper lever. DOH, my '70 didn't have that lever and the therefore the cover was about 1cm too long. shaved it off and voila: the Hub & Wheel fit perfectly ... Andy, Same fix I used on mine. Make sure you cut off enough for the high beam to work when you pull back on the turn signal stalk. I had to cut about 3/8" off. Not good w/ cm's. Don't bother sending it back to me. Maybe it will fit a 911 w/out the big ass (IMG:style_emoticons/default/bootyshake.gif) crack. |
GWN7 |
Jun 14 2003, 12:45 AM
2.5 cm to the inch, so 3/8" is about 1 cm
Hope this dosen't qualify under the "Math" heading (IMG:style_emoticons/default/finger.gif) |
Aaron Cox |
Jun 14 2003, 09:52 PM
QUOTE(MarkV @ Jun 13 2003, 08:55 PM) Don't bother sending it back to me. you can send it to me (IMG:style_emoticons/default/biggrin.gif) im sure i can find someone who needs it....thats how i got the adapter that markv wanted (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 26th April 2024 - 10:05 PM |
