Caliper Porn..., ...silver, plus a peek at GT calipers |
Jeroen |
Mar 19 2005, 10:27 PM
I was wondering the same thing and how about when you bead blast them? |
davep |
Mar 20 2005, 11:18 AM
Update to my previous response on converting 38mm to 42mm pistons.
No, it cannot be done. I forgot about the dust boot. The bore would have to be increased by 4mm, and this would result in too thin of a ring between the groove for the dust boot and the piston bore. If the casting could be welded up, then remachined, perhaps there is a solution. |
Eric_Shea |
Mar 22 2005, 07:05 PM
Sorry for the delayed response, I was out of town for the weekend. (take the I-15 to the 60 to the 83 to the 71 to the 57 to the 210 to the 134 to the 101 to the 134 to the 210 to the I-15... god, I love LA)
Qarl... zinc. I plate them first and then hone the bores. Clearance isn't a huge issue, the sealing ring takes care of that. Jeroen... bead blasting isn't an issue either. We simply don't bead blast directly into the bore. A standard brake cylinder hone found at your FLAPS will clean up everything. All the pistons get buffed to a mirror finish on a wheel and then tapped off and the tops get bead blasted to bare metal. Those get repainted with grey heat paint. |
redshift |
Mar 22 2005, 07:11 PM
It's worth buy these things just to look at.
(IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Man, those S calipers are super sweet! M |
tat2dphreak |
Mar 26 2005, 04:09 PM
hey Eric, got the Front Calipers yesterday, and the Rears today... I was so happy to see them, I forgot to take pics of the fronts before they were mounted...
here are some shots... amazing product, amazing service!! no problems on the install... Attached image(s) |
tat2dphreak |
Mar 26 2005, 04:10 PM
one more... lots more HEREtoo
Eric_Shea |
Mar 26 2005, 07:28 PM
Glad they made it! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Lo-Fi Version | Time is now: 18th May 2024 - 10:43 AM |
