1970 porsche 914 ignition switch wiring, How does original ignition switch differ from new aftermarket switch. |
radobard |
Feb 3 2016, 10:19 AM
Newbie Group: Members Posts: 2 Joined: 15-January 16 From: San Antonio, TX Member No.: 19,563 Region Association: None |
I just replaced my ignition switch on my 1970 porsche 914 4. The replacement switches have four wires connected , red, red/white, black, and grey. My original switch had five wires, red, red/black, black, grey, and a copper see through wire. First question, does the red/ white wire on the original replace the red/black wire on the new? Second question, what is the function of the copper see through wire? If I don't have it in the replacement switch, will something not work? Here is a photo of an original switch with the five wires. The see through copper looking wire is at the top.
3d914 |
Feb 3 2016, 09:08 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
The image below shows the switch (26) on the schematic.
Red wire (#30 at connection #12) goes to the fuse box (Fuse 11), the main light switch, and battery positive. This should be a thick wire. White wire (#34) appears to go to the adjacent signal switch in the column. Red/White wire (#35 at connection 13) also goes to the light switch. Black wire (#15 at connection 8) goes to fuse box (Fuse 8) and to the rear relay board in the large connector at pin 8. Yellow wire (#36 at connection 10) also goes to the rear relay board in the large connector at pin 1. Doesn't look like you can do without any of these. Haynes has a good manual for the 914 with all the schematics. May prove helpful. |
pdlightning |
Feb 3 2016, 10:47 PM
Member Group: Members Posts: 207 Joined: 4-February 11 From: Santa Clarita Member No.: 12,660 Region Association: Southern California |
The image below shows the switch (26) on the schematic. Red wire (#30 at connection #12) goes to the fuse box (Fuse 11), the main light switch, and battery positive. This should be a thick wire. White wire (#34) appears to go to the adjacent signal switch in the column. Red/White wire (#35 at connection 13) also goes to the light switch. Black wire (#15 at connection 8) goes to fuse box (Fuse 8) and to the rear relay board in the large connector at pin 8. Yellow wire (#36 at connection 10) also goes to the rear relay board in the large connector at pin 1. Doesn't look like you can do without any of these. Haynes has a good manual for the 914 with all the schematics. May prove helpful. Does that mean the replacement switch doesn't have enough wires? All of the replacement switches I have seen for the 70-71 4 cyls have only four wires. The 6 cyls have a reg 911 multi pin replacement switch. |
Lo-Fi Version | Time is now: 24th May 2024 - 04:42 PM |
