1970 porsche 914 ignition switch wiring, How does original ignition switch differ from new aftermarket switch. |
radobard |
Feb 3 2016, 10:19 AM
Newbie Group: Members Posts: 2 Joined: 15-January 16 From: San Antonio, TX Member No.: 19,563 Region Association: None |
I just replaced my ignition switch on my 1970 porsche 914 4. The replacement switches have four wires connected , red, red/white, black, and grey. My original switch had five wires, red, red/black, black, grey, and a copper see through wire. First question, does the red/ white wire on the original replace the red/black wire on the new? Second question, what is the function of the copper see through wire? If I don't have it in the replacement switch, will something not work? Here is a photo of an original switch with the five wires. The see through copper looking wire is at the top.
JeffBowlsby |
Feb 28 2016, 12:05 AM
914 Wiring Harnesses Group: Members Posts: 8,516 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
That clear jacketed solid flat copper conductor goes up into the mechanical section of the keyed ignition lock mechanism, it is not part of the electrical ignition switch. I ohmed out the circuits and it appears to be the ground for the buzzer because it grounds at the first click of the key switch, is off otherwise.
914Mike |
Feb 28 2016, 12:49 PM
Member Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
That clear jacketed solid flat copper conductor goes up into the mechanical section of the keyed ignition lock mechanism, it is not part of the electrical ignition switch. I ohmed out the circuits and it appears to be the ground for the buzzer because it grounds at the first click of the key switch, is off otherwise. I seem to remember that wire was grounded by the key itself when it was inserted all the way on my '71, maybe that's different on '70? Makes sense that the buzzer only sounds if the door is open with the key still in... |
Lo-Fi Version | Time is now: 24th May 2024 - 06:19 PM |
