Need help with electronics, fog lamps and odometer on 75-914 |
Vjgtrybno1 |
Mar 19 2005, 09:01 PM
Newbie Group: Members Posts: 2 Joined: 26-September 04 From: Cincinnati, OH Member No.: 2,835 |
Hi,
We just finished restoring a 1975 914-1.8 and need a little help with some finishing touches. Before we started, the fog lamps and odometer were working fine, now that we're finished, they don't. I've replaced the relays on the fusebox to no avail. Any suggestions? Thanks. |
ws91420 |
Mar 19 2005, 09:06 PM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
The odometer is mechanical. See Dave Darling's tech aricle to repair it on Pelican Parts.
Joe Bob |
Mar 19 2005, 09:20 PM
Check the cable.....disconnect at the trans and run it a drill motor....if it does not register at the speedo, check the connection on the back of the speedo...disconnect, run the drill motor again....if it does turn you have a break in the cable..if it does turn most likely a gear broken in the gauge.
On the fogs, make sure the regular lights are on low beams and turned ON...they won't run on high beam. |
Lo-Fi Version | Time is now: 4th May 2024 - 10:58 PM |
