> 1980 model 911 3.0 in 914, Flywheel question and others?
porschetub
post Feb 6 2016, 10:44 PM
Post #21
Hi guys ,for those that have an SC 3.0 in these cars I need the following info as I have been offered for a great price a complete motor with 123K kms documented history.
Anyone got over the situation of clearing the engine lid over the injection system,my lid is sans rain tray and setup for a six already,if that means s#it all.
Been on PMS site and thought there was a conversion flywheel for this engine swap?as silly as it sounds can I engineer a 215mm flywheel to nine bolt crank and fit that,torque figures are not hugely different from say a 911T or 911E of that era.
Flame if you like but I don't want to go to the larger clutch/flywheel and the changes required to get the thrust bearing movement corrected,as in push clutch to pull clutch action.
I feel that I would be happy with this motor the owner is known to me and has a good reputation for honesty,his motivation for selling is an upgrade to a 3.2 in his 76 911s and then finding it needs a fully top overhaul,his motivation for selling the 3.0.
porschetub   1980 model 911 3.0 in 914   Feb 6 2016, 10:44 PM
Dave_Darling   The "conversion flywheel" is a 901-style...   Feb 6 2016, 11:07 PM
JmuRiz   ...The CIS can be flipped around 180 degrees and ...   Feb 8 2016, 10:13 AM
mepstein   ...The CIS can be flipped around 180 degrees and...   Feb 8 2016, 10:34 AM
Mark Henry   ...The CIS can be flipped around 180 degrees and...   Feb 8 2016, 10:53 AM
porschetub   ...The CIS can be flipped around 180 degrees and...   Feb 8 2016, 08:11 PM
Mark Henry   [quote name='JmuRiz' post='2300184' date='Feb 9 2...   Feb 8 2016, 08:51 PM
boxsterfan   Do the 3.0L but put ITB's on it and run with M...   Feb 7 2016, 12:01 AM
porschetub   Do the 3.0L but put ITB's on it and run with ...   Feb 7 2016, 02:32 AM
rhodyguy   Thousands. Not just a couple either.   Feb 7 2016, 11:37 AM
Jeffs9146   Here is what I did with my CIS! No cutting. N...   Feb 7 2016, 12:23 PM
porschetub   Here is what I did with my CIS! No cutting. ...   Feb 7 2016, 05:50 PM
mepstein   PMS gets it all from kep - Kennedy engeneering pro...   Feb 7 2016, 12:40 PM
rgalla9146   You have machine shop skill. The clutch/flywh...   Feb 7 2016, 03:02 PM
boxsterfan   Never tried it myself. http://www.bitzracing.com/...   Feb 7 2016, 10:56 PM
Mark Henry   I built my own clutch set-up the flywheel is stock...   Feb 7 2016, 11:15 PM
Mark Henry   The only thing I'll say is bad with the KEP or...   Feb 7 2016, 11:25 PM
Mark Henry   Been on PMS site and thought there was a convers...   Feb 7 2016, 11:39 PM
Jeffs9146   Sort of! I used a grinder and removed the f...   Feb 8 2016, 01:06 PM
Series9   Here's the thing about CIS: It basically has ...   Feb 8 2016, 09:08 PM
Jeffs9146   Mine is built to drive so I wanted the ability to ...   Feb 8 2016, 11:00 PM
porschetub   What can I say the response has been amazing thank...   Feb 9 2016, 12:43 AM
porschetub   What can I say the response has been amazing than...   Feb 10 2016, 01:02 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:41 AM
